Two books : Lung Mechanics & Fundamentals of Biomedical Engineering
eliker bahij
20 أكتوبر 2010
[h=1]Two books : Lung Mechanics[/h][h=1]& Fundamentals of Biomedical Engineering[/h]
Lung Mechanics: An Inverse Modeling Approach
With mathematical and computational models furthering our understanding of lung mechanics, function and disease, this book provides an all-inclusive introduction to the topic from a quantitative standpoint. Focusing on inverse modeling, the reader is guided through the theory in a logical progression, from the simplest models up to state-of-the-art models that are both dynamic and nonlinear. Key tools used in biomedical engineering research, such as regression theory, linear and nonlinear systems theory, and the Fourier transform, are explained. Derivations of important physical principles, such as the Poiseuille equation and the wave speed equation, from first principles are also provided. Example applications to experimental data throughout illustrate physiological relevance, whilst problem sets at the end of each chapter provide practice and test reader comprehension. This book is ideal for biomedical engineering and biophysics graduate students and researchers wishing to understand this emerging field.
File size: 2.1 MB
File type: PDF
http://depositfiles.com/files/vm0fziwl4
[h=1]Fundamentals of Biomedical Engineering[/h]
A well set out textbook explains the fundamentals of biomedical engineering in the areas of biomechanics, biofluid flow, biomaterials, bioinstrumentation and use of computing in biomedical engineering. All these subjects form a basic part of an engineer's education. The text is admirably suited to meet the needs of the students of mechanical engineering, opting for the elective of Biomedical Engineering. Coverage of bioinstrumentation, biomaterials and computing for biomedical engineers can meet the needs of the students of Electronic & Communication, Electronic & Instrumentation, Information Technology and Biotech Engineering.
The book presents succinct coverage of the theory, definitions, formula and examples and is well supported by plenty of clear-cut diagrams and worked problems in order to make the underlying principles easily comprehensible.
File size: 3,46 Mb
File type: PDF
http://depositfiles.com/files/0amgo97vr
