The Prying Force in Bolts
امين الزريقي
22 سبتمبر 2008
هذا شرح عن طريقة حساب قوة الاجهاد الزائد Prying Force في براغي الربط في وصلات الاعضاء المعدنية التي تستخدم فيها البراغي . هذه القوة التي تنشأ نتيجة للتشوهات الحادثة في صفيحة الوصل.
This is another useful construction tutorial from Dr. Chirag Patel. In this video, you will learn
how to make detail measurement for "Prying Force" in bolted steel structural connection as well as remove it’s effect
In a tension or hanger connection, the operative load creates tension in the bolts and the bolts are designed as tension members. If the connected plate is admissible to deform, supplementary tensile forces known as prying forces are developed in the bolts.
In this video example is given for verifying the exact capacity of a D hanger connection based on the following dimension :-
Bolt Diameter = 30 mm
Bolt Grade = 4.6
Dimension of end plate = 230 x 150 mm
Thickness of T-flange = 32 mm
The connection will not collapse if the tension capacity is higher than total load. Here, tension capacity is taken as 200 kN
:To learn the detail calculation process, go through the following video tutorial
  • prying-force-calculation-and-design-method-for-t-shaped-tensile-connector-with-h-pr_.pdf
    682.2 KB · المشاهدات: 19
  • Prying Force Calculation.pdf
    6.9 MB · المشاهدات: 22
mecheil.edwar
6 سبتمبر 2009
دائما تقدم لنا موضوعات مميزة
