Process Lasso Pro 4.00.33 Final
business2010
14 نوفمبر 2010
Process Lasso Pro 4.00.33 Final Multilingual | 5 MB
Process Lasso is a unique new technology that will, amongst other things, improve your PC's responsiveness and stability. Windows, by design, allows programs to monopolize your CPU without restraint -- leading to freezes and hangs. Process Lasso's ProBalance (Process Balance) technology intelligently adjusts the priority of running programs so that badly behaved or overly active processes won't interfere with your ability to use the computer!
Process Lasso also offers an assortment of ways to take full control of how your CPUs are allocated to running programs. You can choose at what priority processes should run, and which CPUs (cores) should be assigned to them. You can also disallow certain programs from running, log all programs run, and so much more (see list below).
Once you install Process Lasso, it'll just start working. More advanced users can tweak the configuration, but you needn't touch anything to have it instantly improve your system responsiveness and prevent stalls in high load situations.
For network admins, Proces Lasso works wonderfully on Terminal Servers and in multi-user environments. We have many clients that have been using Process Lasso on their Terminal Servers for years.
Best of all, Process Lasso is written in native C++, not .NET. This means it consumes very few system resources - considerably less than any similar software.
Process Lasso Features
Prevent processes from monopolozing the CPU(s)
ProBalance dynamic priority optimization
CPU throttling (new)
Save process priorities for future instances
Save process CPU affin
Process Lasso Pro:
[.4]Fix.GUI: Fix to DEL keyboard accelerator when in new 'Active Processes' tab
[.4]Change.GUI.Server.Edition: Use CHM help docs like the standard edition now does
[.4]Change.GUI.Server.Edition: Post-activated text in about box tweaked a bit
[.4]Change.GUI.Server.Edition: Licensing for the Server Edition is now performed entirely via activation codes
[.4]Change.GUI.Server.Edition: Removed 'Highest Rights' warning, as it is not applicable to Server installs
[.4]Change.GUI: Rewrote 'Highest Rights' warning so its more concise
[.4]Change.GUI: Message box warning now emitted when installed on a server (should use Server Edition)
[.4]Change.GUI: Tweaked synchronizaton objects used by the Active processes tab code
[.4]Change.Core: Log entry warning now emitted when installed on a server (should use Server Edition)
[.4]Change.CPUEater: Changed default CPU Eater demo time to 30 seconds
OS : Win XP/2000/Vista/Win 7
Language : Multilingual
DOWNLOAD :
http://to-upload.com/do.php?id=34
