One simple question, but very urgent brothers
keewan
4 أبريل 2015
HI
after finishing my model on Etabs
I would like to know value of w(load) to use it in deflection equations
so I am thinking of getting w by taking the moment from Etabs ,to get the load,
is this proper ,if yes give me example please
وسيمبوست
21 يناير 2008
?question is not clear-which load you mean
?and what equation you need to use for deflection
keewan
4 أبريل 2015
Let us assume that we get analysis results from Etabs(Moment results),and for some reason I don't want to get deflection values from etabs, instead I would like to calculate Ie manually and calculate deflection manually ,and we all know for any deflection equation we need the value of load applied, so my question is like the following
----what is the value of load on the beam(can I use moment value to get load value or is there any other method(Note load on slab is clear ,as we assign it ,but load on beam will be distributed by Program Etabs)
-----the second question, when calculating deflection values and compare with American code, why we don’t take into consideration snow load and earthquake load
انس مصطفى
21 أغسطس 2013
You can distribute the load you assigned to the slabs to beams manually by dividing two-way slabs into triangles with 45 degrees, or one-way slabs into rectangles as in the attached pic.
we don't include seismic, wind and snow loads in the calculation on "vertical" or "gravity" deflection because they are "Instantaneous" loads .
    15.8 KB · المشاهدات: 7
