Nero Multimedia Suite 10 Platinum HD v10.5.10900 Full (x32/x64) MULTi - Silent Installation
business2010
14 نوفمبر 2010
Nero Multimedia Suite 10 Platinum HD v10.5.10900 Full (x32/x64) MULTi - Silent Installation | 1.91 GB
Nero Multimedia Suite 10 Platinum HD - ready multimedia package of 3 to 1 for video editing, burning and backup. Single powerful package of Nero Multimedia Suite 10, consisting of three products - Nero Vision Xtra â„¢, Nero Burning ROM â„¢, Nero BackItUp & Burn â„¢ - gives users a maximum of multimedia capabilities.
System requirements:
Minimum system requirements for Nero Multimedia Suite 10 Platinum HD
Windows آ® XP SP3 (32-bit), Windows Vista آ® SP1 and above (32 - and 64-bit versions), Windows آ® July Home Premium, Professional, or Ultimate (32 - and 64-bit versions)
Processor AMD or Intel آ® 2 GHz, 512 MB RAM (1 GB of RAM for Windows Vista آ® or Windows آ® 7)
To play Blu-ray Disc and HD-video editing: CPU Intel آ® Core â„¢ II Duo 2,2 GHz, AMD Athlon 64 X2 5200 + 2.6 GHz or higher, 2 GB RAM
5 GB of free hard disk space for typical installation of all components (including templates, *******, and the temporary space on disk)
DirectX آ® 9,0-compatible graphics card with 3D-accelerated, 16-bit color and at least 128 MB of graphics memory (32 bits, true color, 256 MB of dedicated video RAM and support for Shader Model 3,0)
For playback of Blu-ray: a graphics card NVIDIA 8600 or above, ATI Radeon HD 3800 and above, Intel G45 (Windows Vista / Windows 7), minimum 512 MB of video memory, a display that is compatible with HDCP for digital connection
DVD-ROM drive for installation and play; drive that supports Blu-ray playback BD
Recordable or rewritable drive for burning and CD-ROM, DVD or Blu-ray
DirectX آ® 9,0 c revision 30 (August 2006)
Windows Media آ® Player 9
Third-party components, such as Microsoft Windows آ® Installer 4,5, Microsof. NET â„¢ 3,5 SP1 and Microsoft Silverlight â„¢ 3, supplied with the product or, if not included in the package are automatically downloaded from the Internet
For individual services and the use of BD-LIVE features require an Internet connection (recommended DSL-1000 and higher). Costs for connection to the Internet user's responsibility
Note:
In 64-bit operating systems, applications run in emulation mode 32-bit environment
Nero DiscCopy Gadget does not work in 64-bit operating system
To the software worked correctly, the device must be correctly installed and recognized by the operating system
It is strongly recommended that you install the latest WHQL-certified device drivers
Special/minimum requirements for editing and creating video
OHCI-compatible controller آ«FireWire آ®آ» (IEEE one thousand three hundred and ninety-four) for capturing digital video, or HDV â„¢
TV tuner and video capture card to capture video in both analog and digital format
Up to 50 GB of available hard disk space for disk images and temporary files
To support technology NVIDIA آ® CUDA â„¢, you must install a video card that is compatible with the NVIDIA آ® CUDA â„¢. More information can be found at the site
Specials/minimum requirements for backup
To use certain features backup and recovery requires a hard disk with NTFS
For backup using Nero Online Backup requires broadband Internet access
Special/minimum requirements for use LightScribe and Labelflash â„¢
LightScribe-compatible burner and media.
Installed on the computer software to use LightScribe.
Labelflash â„¢-compatible burner and media.
Attention!
By installing and using the program - the Internet should always be turned off and not to rock any.Inache all the keys will be banned.
OS: Windows All (x32/x64)
Language: MULTi
DOWNLOAD :
http://www.filesonic.com/file/45165967
http://www.filesonic.com/file/45165957
http://www.filesonic.com/file/45167255
http://www.filesonic.com/file/45167575
http://www.filesonic.com/file/45168556
http://www.filesonic.com/file/45170247
http://www.filesonic.com/file/45171488
http://www.filesonic.com/file/45172805
http://www.filesonic.com/file/45173554
bakker
2 سبتمبر 2009
link
dose'nt work
