Microstran Limcon v3.62.140220 build 20.02.2014 - steel connections design
محمد ابو مريم
14 مايو 2006
Homepage
setup steps
Software +patch
1- install limconv3_demo_au.exe in install folder
2- install @limcon3_20140106_pass_8877.exe in install folder, with 8877 as password.
3- copy Lmc3.exe from patch folder to C:\Limcon\Program
4- copy all files inside Lib folder to C:\Limcon\Lib folder​
Download
software+patch
limcon36.pdf manual
ولا تنسونا من صالح دعائكم
"إِنْ أُرِيدُ إِلَّا الْإِصْلَاحَ مَا اسْتَطَعْتُ وَمَا تَوْفِيقِي إِلَّا بِاللَّهِ عَلَيْهِ تَوَكَّلْتُ وَإِلَيْهِ أُنِيبُ (88) "هود​
رابط حديث
التعديل الأخير بواسطة المشرف:
ayelamayem77
17 مارس 2012
اخي أبو مريم
أرجو الرفع علي رابط أخر و ليكن media-fire أو 4sheared
م / عمر الجوهرى
27 يونيو 2014
لو ممكن بعد اذنك يا هندسة ملفات مكتبات القطاعات الموجوده ف lib folder عشان بعد ما سطبت مش لاقى غير Asw.lib فقط
محمد ابو مريم
14 مايو 2006
Bentley Limcon v3.63.01.11 build 13.06.2014
In November of 2013 Microstran software products (Limcon, MStower, Microstran) are now part of Bentley Systems
Limcon is productivity-geared steel connection design software. Connection types include beam to column, brace end, member splices, anchorage to concrete, and complicated multi-member joints. By using a library of standard connection types, designers can arrive at results in a remarkably short time.
Comprehensive limit state design to a number of international standards.
Shear and moment connections, member splices, brace end connections, base plates, and hollow section connections.
Connections may be auto-designed by program or specified directly by user.
Concise calculation summary, reporting results for all relevant limit states.
Output to CAD format directly from design.
Introduction to Limcon - Steel Connection Design
Limcon - Structural Analysis and Design - Wiki - Structural Analysis and Design - Bentley Communities
download
Download
ayelamayem77
17 مارس 2012
download
Download
أرجو الرفع علي رابط أخر و كل عام و أنتم بخير
ayelamayem77
17 مارس 2012
شكرا تم التنزيل و تفعيل الكراك شكرا أخي محمد أبو مريم علي هذا البرنامج
medokamel
19 يناير 2013
لا استطيع تحميل البرنامج نهائيا ارجوا اعطاء رابط يعمل
khalat
17 يوليو 2006
أخى العزيز
عندك فيديو تعليمى شلون يشتغل (يصمم) أرجو أن تفيدنا
medokamel
19 يناير 2013
ارجو الرفع علي رابط اخر mega
galal980
4 أغسطس 2007
ممكن ال Patch الخاص بويندوز 64؟
