mechanical seal
shadyabdelhaleem
5 سبتمبر 2006
ما هو ال mechanical seal ببساطة والاهم هل هو يلامس السائل الذي تضخه المضخة وفي اي جزء يلامسه
انا مش مهندس ولا فني لذلك السؤال قد يبدو غريب
عمارسامي
9 مايو 2008
الميكانيكل سيل عبارة عن حشوة ميكانيكية يوضع في منطقة دخول الشفت الى المضخة حيث يقوم بمنع خروج السائل المضغوط من المضخة الى الخارج .
وشكرااا
soud54
14 يناير 2007
Mechanical Seals are quite complicated assemblies when compared to a Gland Packing arrangement. There are many different types of Mechanical Seals for different applications. Illustrated below is a General Assembly Drawing of a typical Single Bellows Type Mechanical Seal.
Seal Flush
from Pump Discharge
Mechanical Seals can generally be split into two basic sub-assemblies:
• The Rotating Assembly.
The rotating assembly within the Mechanical Seal is fitted and attached to the Pump or Compressor Shaft.
As the Pump or Compressor Shaft spins, the Mechanical Seal Rotating Assembly rotates within the Mechanical Seal.
• The Stationary Assembly.
The stationary assembly within the Mechanical Seal is fitted and attached to the Pump or Compressor casing. This part of the Mechanical Seal remains stationary and does not rotate with the Pump or Compressor rotor.
A half section of the same Single Bellows Mechanical Seal as detailed previously in this Module can be viewed in the diagram below. The two Mechanical Seal sub-assemblies; the rotating assembly and the Stationary assembly are Clearly detailed in the following illustration.
عمراياد
10 فبراير 2007
تفضل حمل ملف بهيئة بور بوينت عن ال meachanical seal
هنا
بالتوفيق
