Max Registry Cleaner 6.0.0.046 Portable
business2010
14 نوفمبر 2010
Max Registry Cleaner 6.0.0.046 Portable | 7.06 MB
Max Registry Cleaner provides solution to Windows registry related problems. It scans the Windows registry and finds incorrect or obsolete information. You can safely clean, repair and optimize the Windows registry by fixing this obsolete information. By using a Max Registry Cleaner regularly and fixing registry errors your system will run faster, will be more stable and error free.
The Windows registry is a database repository for information about a computer's configuration. The registry keep growing when you use Windows. As it does so, it attracts obsolete and unnecessary information, and gradually becomes cluttered and fragmented. With the growing of the registry, it can degrade the performance of the whole system and cause many weird software problems.
• With Max Registry Cleaner you can safely clean, repair and optimize the Windows registry with a few simple mouse clicks!
• Avoid problems with the Windows registry that are a common cause of Windows crashes, slow performance and error messages.
• Improve your system performance without expensive hardware upgrades.
• Complete analysis of the detected registry entries with the threat levels
• Safe Backup of any repairs made that you can easily recover any changes if required.
• Personalized E-Mail support by our Research Team
Benefits
• Optimize, speed up and cleanup your PC
• Fix Windows Start-up application errors
• Load windows faster and reduce windows startup time
• Run applications smoothly and prevent application crashes
• Regain disk space
• Fix certain application errors and increase the stability of the overall system
• Maintain your PC like new
Home Page: http://www.maxregistrycleaner.com/
Download link
http://to-upload.com/do.php?id=76
