Lynda – Revit Architecture 2016 Essential Training (Metric - الروابط من رفعى
علاء عبدالحليم
2 مايو 2007
Beginner | 11h 59m | 2.74 GB | Project Files | Software used: Revit Architecture 2016
Info: Take your Revit skills to the next level with Revit Architecture 2016. This course, recorded entirely inmetric units, teaches you the techniques you need to complete solid architectural projects in Revit 2016. First, get comfortable with the Revit environment, and learn to set up a project and add the grids, levels, and dimensions that will anchor your design. Then author Paul F. Aubin helps you dive into modeling: adding walls, doors, and windows; creating and mirroring groups; linking to external assets and DWG files; and working with floors, roofs, and ceilings. Paul also shows advanced techniques for modeling stairs, complex walls, and partially obscured building elements, as well as adding rooms and solid geometry. Finally, discover how to annotate your drawing so all the components are perfectly understood, and learn how to output sheets to DWF, PDF, or AutoCAD.
روابط التحميل
http://www.gulfup.com/?oV4fM7
http://www.gulfup.com/?Tx5hts
http://www.gulfup.com/?2pN5hF
http://www.gulfup.com/?fg0WFk
http://www.gulfup.com/?zYk3zj
http://www.gulfup.com/?OWVq4U
http://www.gulfup.com/?mcZO5g
او
http://filerio.in/oq71qdvgclm1
http://filerio.in/5btsu7u323nk
http://filerio.in/9thvkhvy76qj
http://filerio.in/hioqegrsryd9
http://filerio.in/1mc3pyhc1jug
http://filerio.in/3vjj499u2sjr
http://filerio.in/zsl0lgi9cwfn
arch.jehad
16 أكتوبر 2013
بارك الله فيك , ألا يوجد أي جديد بما يخص تقنيات الفاميلي والماس في الريفيت ؟
Terminator 2013
16 أكتوبر 2013
الروابط منتهيه
رجاءا اعادة الرفع على موقع اخر
