Install Autodesk Structural Bridge Design 2014 اضافة رائعة للمصممين
فواز الجبوري
13 مايو 2010
Read me:
1.Install Autodesk Structural Bridge Design 2014 Products.
You can down load from here:
http://trial2.autodesk.com/SWDLDNET..._Design_2014_R1_English_Win_32bit_DLM.sfx.exe
2.Use as Serial 400-12345678, 666-69696969, 667-98989898, 400-45454545, 066-66666666 ..
or anything matching those templates.
3.Use the Product Key: 954F1 to install
4.Copy and over write 3 files from Zip file to :
C:\Program Files\Common Files\Autodesk Shared\AdLM\R7\ (for windows 32 bit)
C:\Program Files (x86)\Common Files\Autodesk Shared\AdLM\R7\ (for windows 64 bit)
5.Finish the installation & restart Autodesk Product
ACTIVATION : We suggest blocking outgoing traffic (faster and easier to activate)
6.Before clicking on Activate
You have 2 options :
- a) Disable Your network Card, pull the network cable out or block with firewall
(this is just to disable online checks) it will tell you that an internet Connection is Required
simply click on close and click on activate again
OR
Click on Activate and it will do an online check, simply click
on close and click on activate again.
Choose option a or b.
6. Select I have an activation code from Autodesk
7.Once at the activation screen:
start XFORCE Keygen 32bits version as administrator and with UAC off
8.Click on Mem Patch (you should see successfully patched)
9.Copy the request code into the keygen and press generate
10.Now copy the activation code back to the activation screen and click Next
You have a fully registered autodesk product
ENJOY......By DVT !
Note: I already check and sucessfull activation on both windows 32 & 64 bit.
رابط النسخة التجريبية للبرنامج ...
http://trial2.autodesk.com/SWDLDNET3/2014/SBRDES/DLM/Autodesk_Structural_Bridge_Design_2014_R1_English_Win_32bit_DLM.sfx.exe
أما الكيجن .زفكيجن الاوتوديسك 2014 ..أكيد تعرفوه ..طبتم..
Link down load install set:
https://mega.co.nz/#!8sM21Jza!bTJtJdA8WUKdtpN0omnFvpx_GT9GZ6w9sGFizeHLfws
رابط
https://mega.co.nz/#!dtcEAJrJ!Vr7alfPgmiYHZ43-9Mq63Kb0CYxufNrrxtDVcy2yf8M
khhiisb
13 مارس 2013
مشكور وجزاك الله الف خير
