InfiniteSkills – Learning Autodesk AutoCAD 2016 - الروابط من رفعى
علاء عبدالحليم
2 مايو 2007
Info:In this Learning Autodesk AutoCAD 2016 training course, expert author Brian Benton will teach you how to
create 2D drawings using the latest version of this computer aided design software from Autodesk. This
course is designed for the absolute beginner, meaning no experience with AutoCAD is required.You will start by learning about the new features in AutoCAD 2016, then jump into learning about the
AutoCAD interface. From there, Brian will teach you basic operations, such as how to quit AutoCAD, work
with the coordinate system, and use the grid system. This video tutorial will also teach you how to use
the drawing and drafting tools, editing tools, and the utilities. You will also cover the precision tools
to help you draw accurately. Brian will teach you how to use layers, annotations, blocks, and model and
paper space. Finally, you will use your skills to create a drawing of a small movie theatre.Once you have completed this computer based training course, you will be fully capable of using AutoCAD
2016 to create your own 2D drawings. Working files are included, allowing you to follow along with the
author throughout the lessons.
روابط التحميل
http://www.gulfup.com/?jpBlzI
http://www.gulfup.com/?kS1pk0
http://www.gulfup.com/?1apg5s
http://www.gulfup.com/?hp0xN8
http://www.gulfup.com/?nzi68M
http://www.gulfup.com/?MxLEPU
abedodeh
13 فبراير 2007
بارك الله فيك وشكرا جزيلا جه مميز ربنا يحميك ويجزيك عنا كل الخير
