ImagePDF PDF OCR Compressor Toolkit SDK 2.1 DC02222011
business2010
14 نوفمبر 2010
ImagePDF PDF OCR Compressor Toolkit SDK 2.1 DC02222011 | 5.9 MB
Image To PDF Converter (PDF OCR Compressor Toolkit) is a Windows Application which can directly convert image files (TIF, JPG, GIF, PNG,BMP, PSD, WMF, EMF, PDF, PCX, PIC, etc.) to PDF files. Image To PDF Converter (PDF OCR Compressor Toolkit) does support skew-correct and despeckle for black and white image files. Image To PDF Converter (PDF OCR Compressor Toolkit) software doesn't depend on Adobe Acrobat and Adobe Reader applications.
Product Overview
Image to PDF Converter is a Windows application which can directly convert dozens of image formats, such as TIF, TIFF, JPG, JPEG, GIF, PNG, BMP, PSD, WMF, EMF, PCX, PIC and so on, into PDF format. Image to PDF can automatically clear and skew-correct B/W images by employing special techniques to insure high quality output after conversion. Image to PDF can operate independently of Adobe Acrobat and has faster processing speed. Image to PDF provides a very convenient, simple way to compose electronic books which can then be issued to the Web. You can scan paper documents directly to image files and then convert them to PDF using Image to PDF Converter.
Image to PDF Converter is a Command Line product, it allows you to manually issue commands or include them in scripts, for example, a web site or intranet to convert TIFF or other image files to PDF on the fly. Image to PDF is perfect for high-volume document archive/database systems that require unattended batch image conversions (TIFF or other images) to PDF format.
Image To PDF (PDF OCR Compressor Toolkit) Highlight Features
* Compress color and grayscale pictures into PDF file with JPEG2000 compression
* Compress black and white pictures into PDF file with JBIG2 compression
* Convert existing PDF files to new PDF files with high compression
* Convert scanned TIFF and Image files to full text searchable PDF files
* Convert PDF to BMP, JPEG, GIF, PNG, MNG, TIF, TGA, PCX, JPEG2000 (JP2), etc. image files
Image To PDF Basic Features
* Support TIF, TIFF, JPG, JPEG, PNG, GIF, PCD, PSD, TGA, BMP, DCX, PIC, EMF, WMF, etc. image formats
* Combines multiple directories and images into one PDF file
* Do NOT need Adobe Acrobat software
* Support Win98/ME/NT/2000/XP/2003/Vista platforms (32bit and 64bit systems)
* Support Multi-page image file (TIFF) to PDF conversion
* Support sorting on file name when converting batches
* Set automatic despeckling (of B/W images; removes noise) and skew-correction
* Merge several image files into a single PDF file during batch converting, or convert each image file into individual PDF file
* Makes use of effective compression processing to minimize space occupied by the created PDF files; for example, an A4 paper size TIFF file with a
B/W image the output size is about 40KB to 50KB per page; color and gray-scale images are also compressed and optimized
* Password protection for PDF files with 40 or 128 bit encryption
* Set file permissions to restrict printing, copying, and future modifications to the document
* Automatically open PDF file after creation
* Specify any resolution in the generated PDF file
* Specify paper size (paper width and paper height), rotation, margins to the generated PDF file
* Overwrite, append or insert image files to an existing PDF file
* Set document title, subject, author, keywords, producer, creator, creation date, modify date to PDF
* Generate bookmarks
* Merge to an existing PDF file (insert before the first page or append to the last page)
* Merge several PDF files into one PDF file
* Burst one multi-page PDF file into several PDF files
* Create PDF/A PDF file
* Create PDF/X PDF file
* Set watermark into PDF file, include watermark *******, type, font name, font size, bold, italic, underline, strikeout, angle, text color, X/Y offset, etc. attributes
DOWNLOAD :
ImagePDF.PDF.OCR.Compressor.Toolkit.SDK.v2.1.DC02222011-BEAN_.rar.rar.rar - 5.9 MB
