Help : Fresh concrete frictional drag force
tarek.abulail
22 أكتوبر 2016
I need help in determining the force on horizontal pipe length of 3.0m
The pipe is pumping concrete of 2400kg/m3
Pipe diameter is 125mm
Pumping initial pressure is 130Bar = 13000KPa
Concrete velocity 1.0m/hr
Assuming frictional constant is maybe around 0.45 (I need advice on this one)
The pipe is horizontal.
The purpose of these calculations is to design support for the pipe while pumping concrete.
Please if some Engineer can help in this one
Please assume any reasonable other assumption if you need to.
Excuse me because I don’t have Arabic keyboard
Thank you
tarek.abulail
22 أكتوبر 2016
calcs for checking
Can some one advise me PLZ
  • Fresh Concrete Frictional Drag Force.pdf
    162.2 KB · المشاهدات: 56
tarek.abulail
22 أكتوبر 2016
the geometry of the supports is not the issue please assume anything
i want to confirm the calculation of the forces
Thx for getting back to me
اقليدس العرب
5 سبتمبر 2009
الاحمال لديك ستكون نوعان:
1. وزن الكونكريت مع البايب و يؤثر عموديا على المسند
2.الحمل المتمثل باندفاع الكونكريت في البايب ويؤثر جانبيا المسند
tarek.abulail
22 أكتوبر 2016
Akledes
Thank you again but my issue is to calculate the second type of loading
2.الحمل المتمثل باندفاع الكونكريت في البايب ويؤثر جانبيا المسند??
I need proper calculations for the corces
:34:
