heat integration
mah_9can
20 مايو 2008
Alsalam alikoom all engineers, to day I want to share with you one of the most important thing that shall be calculated in the chemical design process, and I want to give a good example about the heat integration, and how we can calculate the pinching point to the heat exchangers in the chemical plants, so I hope you will be intersted in the below example.
M. Kraimid chemical and corrosion Eng Libya
عسولى
25 يونيو 2006
جزاك الله خير
وربنا يعينكم على ازالة هذا الطاغية
وييسر لكم الخير
