Full set of ACI Codes (مجموعة كودات ال ACI كاملة)
انس مصطفى
21 أغسطس 2013
اقدم لكم مكتبة ال ACI كاملة بجميع كودات ال aci بحجم 360 MB .. وتتضمن التالي :
Contents
Part 1—ACI 117-06 to ACI 224.3R-95(08)
Part 2—ACI 225-99(05) to ACI 315-99
Part 3—ACI 318-08 to ACI 347.2R-05
Part 4—ACI 349-06 to ACI 360R-06
Part 5—ACI 362.1R-97(02) to ACI 503.7-07
Part 6—ACI 506R-05 to ACI ITG-7-09
100—General117-06 Specifications for Tolerances for Concrete Construction and Materialsand Commentary, Part 1121R-08 Guide forConcrete Construction Quality Systems in Conformance with ISO 9001, Part 1122R-02 Guide toThermal Properties of Concrete and Masonry Systems, Part 1126.3R-99 Reapproved 2008 Guide to Recommended Format for Concrete in Materials Property Database,Part 1 200—Materialsand Properties of Concrete201.1R-08 Guidefor Conducting a Visual Inspection of Concrete in Service, Part 1201.2R-08 Guide toDurable Concrete, Part 1207.1R-05 Guide toMass Concrete, Part 1207.2R-07 Reporton Thermal and Volume Change Effects on Cracking of Mass Concrete, Part 1207.3R-94 Reapproved 2008 Practices forEvaluation of Concrete in Existing Massive Structures for ServiceConditions,Part 1207.4R-05 Coolingand Insulating Systems for Mass Concrete, Part 1207.5R-99 Roller-Compacted Mass Concrete, Part 1209R-92 Reapproved 2008 Prediction of Creep, Shrinkage, and Temperature Effects inConcrete Structures, Part 1209.1R-05 Reporton Factors Affecting Shrinkage and Creep of Hardened Concrete, Part 1209.2R-08 Guidefor Modeling and Calculating Shrinkage and Creep in Hardened Concrete, Part 1210R-93 Reapproved 2008 Erosion of Concrete in Hydraulic Structures, Part 1211.1-91 Reapproved 2009 Standard Practice for Selecting Proportions for Normal,Heavyweight, and Mass Concrete, Part 1211.2-98Reapproved 2004 Standard Practice for SelectingProportions for Structural Lightweight Concrete part 1211.3R-02 Reapproved 2009 Guide for Selecting Proportionsfor No-Slump Concrete part 1211.4R-08 Guide for Selecting Proportions forHigh-Strength Concrete Using Portland Cement and OtherCementitious Materialspart 1211.5R-01 Reapproved 2009 Guide for Submittal of Concrete Proportions part 1212.3R-04 Chemical Admixtures for Concrete part 1212.4R-04 Guide for the Use of High-Range Water-ReducingAdmixtures (Superplasticizers) in Concrete part 1213R-03 Guide for Structural Lightweight-AggregateConcrete part 1214R-02 Evaluation of Strength Test Results of Concretepart 1214.4R-03 Guide for Obtaining Cores and InterpretingCompressive Strength Results part 1216.1-07 Code Requirements for Determining FireResistance of Concrete and Masonry ConstructionAssemblies part 1221R-96 Reapproved 2001 Guide for Use of Normal Weightand Heavyweight Aggregates in Concrete part 1221.1R-98 Reapproved2008 Report on Alkali-Aggregate Reactivity part 1222R-01 Protection of Metals in Concrete Against Corrosionpart 1222.2R-01 Corrosion of Prestressing Steels part 1222.3R-03 Design and Construction Practices to MitigateCorrosion of Reinforcement in Concrete Structures part 1223-98 Standard Practice for the Use ofShrinkage-Compensating Concrete part 1224R-01Reapproved 2008 Control of Cracking in ConcreteStructures part 1224.1R-07 Causes, Evaluation, and Repair of Cracks inConcrete Structures part 1224.2R-92 Reapproved2004 Cracking of Concrete Members in Direct Tension part 1224.3R-95 Reapproved 2008 Joints in Concrete Constructionpart 1225R-99 Reapproved2005 Guide to the Selection and Use of Hydraulic Cements part 2228.1R-03 In-Place Methods to Estimate Concrete Strengthpart 2228.2R-98 Reapproved 2004 Nondestructive Test Methods forEvaluation of Concrete in Structures part 2229R-99Reapproved 2005 Controlled Low-Strength Materialspart 2230.1R-09 Report on Soil Cement part 2232.1R-00 Reapproved 2006 Use of Raw or Processed NaturalPozzolans in Concrete part 2232.2R-03 Use of Fly Ash in Concrete part 2233R-03 Slag Cement in Concrete and Mortar part 2234R-06 Guide for the Use of Silica Fume in Concrete part2237R-07 Self-Consolidating Concrete part 2238.1R-08 Report on Measurements of Workability andRheology of Fresh Concrete part 2 300—Designand Construction301-05 Specifications for Structural Concrete part 2SP-15(05) Field Reference Manual (Synopsis only), part 2302.1R-04 Guide for Concrete Floor and Slab Constructionpart 2302.2R-06 Guide for Concrete Slabs that Receive Moisture-SensitiveFlooring Materials part 2303R-04 Guide to Cast-in-Place Architectural ConcretePractice part 2303.1-97 Standard Specification for Cast-In-PlaceArchitectural Concrete part 2304R-00 Guide for Measuring, Mixing, Transporting, andPlacing Concrete part 2304.1R-92 Reapproved2005 Guide for the Use of Preplaced Aggregate Concrete for Structural and Mass ConcreteApplications part 2304.2R-96 Reapproved 2008 Placing Concrete by PumpingMethods part 2304.3R-96 Reapproved 2004 Heavyweight Concrete:Measuring, Mixing, Transporting, and Placing part 2304.4R-95 Reapproved 2008 Placing Concrete with BeltConveyors part 2304.6R-09 Guide for Use of Volumetric-Measuring andContinuous-Mixing Concrete Equipment part 2305R-99 Hot Weather Concreting part 2305.1-06 Specification for Hot Weather Concreting part 2306R-88 Reapproved 2002 Cold Weather Concreting part 2306.1-90 Reapproved 2002 Standard Specification for ColdWeather Concreting part 2307-08 Code Requirements for Reinforced Concrete Chimneys(ACI 307-08) and Commentary part 2308R-01 Reapproved2008 Guide to Curing Concrete part 2308.1-98 Standard Specification for Curing Concrete part2309R-05 Guide for Consolidation of Concrete part 2309.1R-08 Report on Behavior of Fresh Concrete During Vibrationpart 2309.2R-98 Reapproved 2005 Identification and Control ofVisible Effects of Consolidation on Formed Concrete Surfaces part 2309.5R-00 Reapproved 2006 Compaction of Roller-CompactedConcrete part 2311.1R-07 ACI Manual of Concrete Inspection—SP-2(07) (Synopsisonly), Part 2311.4R-05 Guide for Concrete Inspection part 2311.5-04 Guide for Concrete Plant Inspection and Testingof Ready-Mixed Concrete part 2311.6-09 Specification for Ready Mixed Concrete TestingServices part 2313-97 Standard Practice for Design and Construction ofConcrete Silos and Stacking Tubes for Storing Granular Materials part 2313R-97 Commentary on Standard Practice for Design andConstruction of Concrete Silos and Stacking Tubes for Storing GranularMaterials part 2315-99 Details and Detailing of Concrete Reinforcementpart 2SP-66(04) ACI Detailing Manual (Synopsis only), Part 2318-08 Building Code Requirements for Structural Concrete(ACI 318-08) and Commentary part 3SP-71(08) ASTM Standards in ACI 318 (Synopsis only), Part3325.10R-95 Reapproved 2001 Report on Roller-CompactedConcrete Pavements part 3325.11R-01 Accelerated Techniques for Concrete Pavingpart 3325.12R-02 Guide for Design of Jointed Concrete Pavementsfor Streets and Local Roads part 3325.13R-06 Concrete Overlays for Pavement Rehabilitationpart 3330R-08 Guide for the Design and Construction of ConcreteParking Lots part 3330.1-03 Specification for Unreinforced Concrete ParkingLots part 3332-08 Code Requirements for Residential Concrete andCommentary part 3332.1R-06 Guide to Residential Concrete Construction part3334.1R-92 Reapproved 2002 Concrete ShellStructures—Practice and Commentary part 3334.3R-05 Construction of Concrete Shells Using InflatedForms part 3336.1-01 Specification for the Construction of DrilledPiers part 3336.2R-88 Reapproved2002 Suggested Analysis and Design Procedures for Combined Footings and Matspart 3336.3R-93 Reapproved 2006 Design and Construction ofDrilled Piers part 3341.2R-97 Reapproved 2003 Seismic Analysis and Design ofConcrete Bridge Systems part 3341.3R-07 Seismic Evaluation and Retrofit Techniques forConcrete Bridges part 3343R-95 Reapproved 2004 Analysis and Design of ReinforcedConcrete Bridge Structures part 3345R-91Reapproved 2005 Guide for Concrete Highway BridgeDeck Construction part 3345.1R-06 Guide for Maintenance of Concrete BridgeMembers part 3345.2R-98 Reapproved 2005 Guide for Widening HighwayBridges part 3346-09 Specification for Cast-in-Place Concrete Pipe part3347-04 Guide to Formwork for Concrete part 3347.2R-05 Guide for Shoring/Reshoring of ConcreteMultistory Buildings part 3SP-4 Formwork for Concrete (Synopsis only), Part 3349-06 Code Requirements for Nuclear Safety-RelatedConcrete Structures (ACI 349-06) and Commentary part 4349.1R-0 Reinforced Concrete Design for Thermal Effectson Nuclear Power Plant Structures part 4349.2R-07 Guide to the Concrete Capacity Design (CCD)Method—Embedment Design Examples part 4349.3R-02 Evaluation of Existing Nuclear Safety-RelatedConcrete Structures part 4350-06 Code Requirements for Environmental EngineeringConcrete Structures (ACI 350-06) andCommentary part 4350.1-01/ 350.1R-01 Tightness Testing of EnvironmentalEngineering Concrete Structures (ACI 350.1-01) and Commentary (ACI 350.1R-01)part 4350.2R-04 Concrete Structures for Containment ofHazardous Materials part 4350.3-06 Seismic Design of Liquid-Containing ConcreteStructures (ACI 350.3-06) and Commentary part 4350.4R-04 Design Considerations for EnvironmentalEngineering Concrete Structures part 4351.1R-99 Reapproved 2008 Grouting between Foundationsand Bases for Support of Equipment and Machinery part 4351.2R-94 Reapproved 1999 Foundations for StaticEquipment part 4351.3R-04 Foundations for Dynamic Equipment part 4352R-02 Recommendations for Design of Beam-ColumnConnections in Monolithic Reinforced Concrete Structures part 4352.1R-89 Reapproved 2004 Recommendations for Design ofSlab-Column Connections in Monolithic Reinforced Concrete Structures part 4355.2-07 Qualification of Post-Installed MechanicalAnchors in Concrete (ACI 355.2-07) and Commentary part 4357R-84 Reapproved 1997 Guide for the Design andConstruction of Fixed Offshore Concrete Structures part 4357.2R-88 Reapproved 1997 Report on Barge-Like ConcreteStructures (Abstract only) part 4358.1R-92 Analysis and Design of Reinforced andPrestressed Concrete Guideway Structures part 4359-07 Code for Concrete Containments (Synopsis only),Part 4360R-06 Design of Slabs-on-Ground part 4362.1R-97 Reapproved 2002 Guide for the Design of DurableParking Structures part 5362.2R-00 Reapproved 2005 Guide for StructuralMaintenance of Parking Structures part 5363R-92 Reapproved 1997 Report on High-Strength Concretepart 5363.2R-98 Guide to Quality Control and Testing ofHigh-Strength Concrete part 5364.1R-07 Guide for Evaluation of Concrete Structuresbefore Rehabilitation part 5364.2T-08 Increasing Shear Capacity within ExistingReinforced Concrete Structures part 5364.3R-09 Guide for Cementitious Repair Material DataSheet part 5365.1R-00 Service-Life Prediction part 5371R-08 Guide for the Analysis, Design, and Constructionof Elevated Concrete and Composite Steel-Concrete Water Storage Tanks part 5372R-03 Design and Construction of Circular Wire- andStrand-Wrapped Prestressed Concrete Structures part 5373R-97 Design and Construction of Circular PrestressedConcrete Structures with Circumferential Tendons part 5374.1-05 Acceptance Criteria for Moment Frames Based onStructural Testing and Commentary part 5 400—ConcreteReinforcement and Structural Analysis408R-03 Bond and Development of Straight Reinforcing Barsin Tension part 5408.2R-92 Reapproved 2005 Bond under Cyclic Loads(Abstract only) part 5408.3R-09 Guide for Lap Splice and Development Length ofHigh Relative Rib Area Reinforcing Bars in Tension and Commentary part 5421.1R-08 Guide to Shear Reinforcement for Slabs part 5421.2R-07 Seismic Design of Punching Shear Reinforcementin Flat Plates part 5423.3R-05 Recommendations for Concrete MembersPrestressed with Unbonded Tendons part 5423.4R-98 Corrosion and Repair of Unbonded Single StrandTendons part 5423.6-01/ 423.6R-01 Specification for UnbondedSingle-Strand Tendons (ACI 423.6-01) and Commentary part 5423.7-07 Specification for Unbonded Single-Strand TendonMaterials (ACI 423.7-07) and Commentary part 5435R-95 Reapproved 2000 Control of Deflection in ConcreteStructures part 5435.8R-85 Reapproved 1997 Observed Deflections ofReinforced Concrete Slab Systems, and Causes of Large Deflections (Synopsisonly), Part 5437R-03 Strength Evaluation of Existing ConcreteBuildings part 5437.1R-07 Load Tests of Concrete Structures: Methods,Magnitude, Protocols, and Acceptance Criteria part 5439.3R-07 Types of Mechanical Splices for ReinforcingBars part 5439.4R-09 Report on Steel Reinforcement—MaterialProperties and U.S. Availability part 5440R-07 Report on Fiber-Reinforced Polymer (FRP)Reinforcement for Concrete Structures part 5440.1R-06 Guide for the Design and Construction ofStructural Concrete Reinforced with FRP Bars part 5440.2R-08 Guide for the Design and Construction ofExternally Bonded FRP Systems for Strengthening Concrete Structures part 5440.3R-04 Guide Test Methods for Fiber-ReinforcedPolymers (FRPs) for Reinforcing or Strengthening Concrete Structures part 5440.4R-04 Prestressing Concrete Structures with FRPTendons part 5440.5-08 Specification for Construction with Fiber-ReinforcedPolymer Reinforcing Bars, Part 5440.6-08 Specification for Carbon and GlassFiber-Reinforced Polymer Bar Materials for Concrete Reinforcement part 5441R-96 High-Strength Concrete Columns part 5445R-99 Reapproved 2009 Recent Approaches to Shear Designof Structural Concrete part 5446.1R-91 Reapproved 1999 Fracture Mechanics of Concrete:Concepts, Models and Determination of Material Properties (Abstract only), Part5446.3R-97 Finite Element Analysis of Fracture in ConcreteStructures part 5446.4R-04 Report on Dynamic Fracture of Concrete part 5 500—SpecializedApplications and Repair503R-93 Reapproved 2008 Use of Epoxy Compounds withConcrete part 5503.1-92 Reapproved 2003 Standard Specification forBonding Hardened Concrete, Steel, Wood, Brick, and Other Materials to HardenedConcrete with a Multi-Component Epoxy Adhesive part 5503.2-92Reapproved 2003 Standard Specification forBonding Plastic Concrete to Hardened Concrete with a Multi-Component EpoxyAdhesive part 5503.3-92 Reapproved 2003 Standard Specification forProducing a Skid-Resistant Surface on Concrete by the Use of a Multi-ComponentEpoxy System part 5503.4-92 Reapproved 2003 Standard Specification forRepairing Concrete with Epoxy Mortars part 5503.5R-92 Reapproved 2003 Guide for the Selection ofPolymer Adhesives with Concrete part 5503.6R-97 Reapproved 2003 Guide for the Application ofEpoxy and Latex Adhesives for Bonding Freshly Mixed and Hardened Concretes part5503.7-07 Specification for Crack Repair by EpoxyInjection part 5506R-05 Guide to Shotcrete part 6506.1R-08 Guide to Fiber-Reinforced Shotcrete part 6506.2-95 Specification for Shotcrete part 6506.4R-94 Reapproved 2004 Guide for the Evaluation ofShotcrete part 6506.5R-09 Guide for Specifying Underground Shotcrete part6522R-06 Pervious Concrete part 6522.1-08 Specification for Pervious Concrete Pavementpart 6523.1R-06 Guide for Cast-in-Place Low-Density CellularConcrete part 6523.2R-96 Guide for Precast Cellular Concrete Floor,Roof, and Wall Units part 6523.4R-09 Guide for Design and Construction of AutoclavedAerated Concrete Panels part 6524R-08 Guide to Portland Cement-Based Plaster part 6530-08/TMS 402-08/ASCE 5-08 Building Code Requirementsfor Masonry Structures part 6530.1-08/TMS 602-08/ASCE 6-08 Specification for MasonryStructures part 6530R-08/TMS 402-08/ASCE 5-08 Commentary on Building CodeRequirements for Masonry Structures part 6530.1R-08/TMS 602-08/ASCE 6-08 Commentary onSpecification for Masonry Structures part 6533R-93Reappoved 2004 Guide for Precast Concrete WallPanels part 6533.1R-02 Design Responsibility for ArchitecturalPrecast-Concrete Projects part 6543R-00 Reapproved 2005 Design, Manufacture, andInstallation of Concrete Piles part 6544.1R-96 Reapproved 2002 Report on Fiber ReinforcedConcrete part 6544.2R-89 Reapproved 1999 Measurement of Properties ofFiber Reinforced Concrete part 6544.3R-08 Guide for Specifying, Proportioning, andProduction of Fiber-Reinforced Concrete part 6544.4R-88 Reapproved 1999 Design Considerations for SteelFiber Reinforced Concrete part 6546R-04 Concrete Repair Guide part 6546.2R-98 Guide to Underwater Repair of Concrete part 6546.3R-06 Guide for the Selection of Materials for theRepair of Concrete part 6548.1R-09 Guide for the Use of Polymers in Concrete part6548.3R-09 Report on Polymer-Modified Concrete part 6548.4-93 Reapproved 1998 Standard Specification forLatex-Modified Concrete (LMC) Overlays part 6548.5R-94 Reapproved 1998 Guide for Polymer ConcreteOverlays part 6548.7-04 Test Method for Load Capacity of PolymerConcrete Underground Utility Structures part 6548.8-07 Specification for Type EM (Epoxy Multi-Layer)Polymer Overlay for Bridge and Parking Garage Decks part 6548.9-08 Specification for Type ES (Epoxy Slurry) PolymerOverlay for Bridge and Parking Garage Decks part 6549R-97 Reapproved 2009 Report on Ferrocement part 6549.1R-93 Reapproved 2009 Guide for the Design,Construction, and Repair of Ferrocement part 6549.2R-04 Report on Thin Reinforced Cementitious Productspart 6550.1R-09 Guide to Emulating Cast-in-Place Detailing forSeismic Design of Precast Concrete Structures part 6551.1R-05 Tilt-Up Concrete Construction Guide part 6555R-01 Removal and Reuse of Hardened Concrete part 6T1.2-03/ T1.2R-03 Special Hybrid Moment Frames Composedof Discretely Jointed Precast and Post-TensionedConcrete Members and Commentarypart 6ITG-3-04 Report on Bridge Decks Free of SteelReinforcement part 6ITG-4.1-07 Specification for High-Strength Concrete inModerate to High Seismic Applications part 6ITG-4.2R-06 Materials and Quality Considerations for High-StrengthConcrete in Moderate to High Seismic Applications part 6ITG-4.3R-07 Report on Structural Design and Detailing forHigh-Strength Concrete in Moderate to High Seismic Applications part 6ITG-5.1-07 Acceptance Criteria for Special UnbondedPost-Tensioned Precast Structural Walls Based on Validation Testing andCommentary part 6ITG-5.2-09 Requirements for Design of a Special UnbondedPost-Tensioned Precast Shear Wall Satisfying ACI ITG-5.1 (ACI ITG-5.2-09) andCommentary, part 6ITG-7-09 Specification for Tolerances for PrecastConcrete, Part 6SP-17(09) ACI Design Handbook (Synopsis only), Part 6
كلمة السر للملف المضغوط هي
http://www.civilea.com
http://www.4shared.com/rar/ci3_sgWxba/4567vbjn7986.html
anass81
9 مارس 2007
مشكور وبارك الله فيك
إسلام علي
15 مارس 2005
ممكن رابط آخر غير فورشير
خله ميديافاير
ما إصدار هذه الأكواد 2014 ؟
