Design Guide for designing and detailing reinforced concrete diaphragms
hassananas
11 مايو 2006
with the 2014 edition of Building Code Requirements for Structural Concrete (ACI 318-14) and Commentary (ACI 318R-14) [Reference 1].
One of the main goals is to provide step-by-step design procedures and design aids that make designing and detailing reinforced
concrete diaphragms simpler and faster. The procedures and design aids contained in this publication can be used in the design
and detailing of reinforced concrete diaphragms in buildings of any size that are assigned to Seismic Design Categories A through F.
The 2018 edition of the International Building Code (IBC) [Reference 2] references ACI 318-14, and Section 1901.2 of the IBC requires
that structural concrete be designed and constructed in accordance with the provisions of Chapter 19 of the IBC and the
2014 edition of ACI 318 as amended in IBC Section 1905. Thus, ACI 318 is part of the IBC and its applicable provisions must be
satisfied when the IBC is adopted in a jurisdiction.
It is important to note that ACI 318 provides minimum requirements for the materials, design, construction, and strength evaluation
of structural concrete members and systems in any structure designed and constructed under the requirements of the
general building code, such as the IBC. The purpose and applicability of the requirements in ACI 318-14 can be found in Sections
1.3 and 1.4 of that document, respectively.
The requirements of the 2016 edition of ASCE/SEI 7 Minimum Design Loads and Associated Criteria for Buildings and Other Structures
(Reference 3) are also used throughout this publication, including several important provisions pertaining to diaphragm loading
and Seismic Design Category (SDC).
الرابط :
https://www.4shared.com/office/rMmaHSJ9iq/Design_Guide_for_Reinforced_Co.html
احتسبه لوجه الله تعالى , الدعاء لوالدتي بالشفاء اخواني وابنائي
eng-mahfouz
20 فبراير 2014
السلا م عليكم : يرجى من السيد المهندس حسان اذا كان متوفر عنده كتاب وله كل الشكر على كل حالCRSI Webinar Series: Design and Detailing of Reinforced Concrete Diaphragms f
[h=2]David A. Fanella, Ph.D., S.E., P.E[/h]
