Bookmark Docs 2.1.0.0 Portable
business2010
14 نوفمبر 2010
Bookmark Docs 2.1.0.0 Portable | 5.25 MB
Bookmark Docs is an advanced application designed to enable you to add bookmarks and hyperlinks to PDF, CHM, MSDN documents and web pages. As it often happens, information is stored in various formats. Technical documents are often distributed as PDF files. Manuals for applications are usually available in the CHM format. Many software engineers find the MSDN Library indispensable. And we all cannot do without the Web. Bookmark Docs lets you quickly and easily "bookmark" any places in documents and then return to them whenever you need, and do all that in a unified manner.
Iit's very easy to use Bookmark Docs whenever you need to "bookmark" some place, so you can easily return to it in future. While native applications may have some built-in bookmarking features, they only let you bookmark a page or, at best, a paragraph of the document. Bookmark Docs allows you to position your bookmark much more precisely. Moreover, a team of users can work on groups of bookmarks, and bookmarks can be categorized by tags.
Bookmark Docs' another key feature is the extensive use of hyperlinks for all supported document formats. You can easily define a URL for any place in the document. You can also add URLs to other documents, to send those URLs to someone else, and more. Besides, generating hyperlinks with Bookmark Docs means that you can use bookmarks to information stored in PDF, CHM, and MSDN formats via a bookmark manager of your choice.
For example, you can manage your bookmarks with Google Bookmarks. Bookmark Docs can even generate short URLs. Bookmark Docs has a simple, user-friendly interface. Supported formats: PDF, CHM, MSDN Library, and Web pages
DOWNLOAD :
http://to-upload.com/do.php?id=37
