Auslogics Registry Defrag 6.0.4.45
business2010
14 نوفمبر 2010
Auslogics Registry Defrag 6.0.4.45 | 5.3 Mb
Auslogics Registry Defrag can improve your system’s performance by Compacting and Improving your System’s Ability to Access the Windows Registry. In theory, and as programs are installed and/or removed from a system, the registry will not only grow in size but will also lose its linear structure, making it less responsive and causing increased access times.
A registry defragmentation can reverse this, eliminating useless space that was previously allocated to now uninstalled applications as well as restore a linear structure to the registry that optimizes access times.
System Optimization
Microsoft Windows and various program access the registry a few hundred times a second. By keeping your registry optimized you improve your computer performance.
Complete Registry Defragmentation
Data is frequently removed from the registry, but the allocated space remains. The program will scan through the registry to remove this space, reducing the size of the registry.
Ease of Use
Registry Defrag is incredibly easy to use even for a novice user. The program provides stunning visual representation of the fragmented areas in your registry.
Detailed Reports
Upon defragmenting the registry on your computer, the program prepares an HTML report with comprehensive details about registry defragmentation process.
- various interface fixes
- fixed all known compatibility problems
- improved general speed
- improved stability and reliability
- fixed all known bugs
- updated localizations
- improved installer
DOWNLOAD :
http://to-upload.com/do.php?id=21
