طلب مساعدة في MCU +FM Receiverبا رك الله فيكم
lg019547
20 مايو 2006
السلام عليكم عندي مشروع تخرج
مو استقبال أخبار عن طريقSi4705) FM RADIO RECEIVER) الدي يرسل digital audio الى MCU power source 3.3)C8051F411 ) هدا الأ خير يرسلها االى Flashmemoryلتخزين.مشكلتي اني اتممتschematic واسلته الى المنتج الدي أجابني بالتالي
Here goes with the feedback. Please feel free to filter or pretty it up as needed
1) With GPIO disconnected the bus will default to 2-wire I2C mode. I think they should have pull-up resistors on SCLK and SDIO.
2) What kind of antenna is intended to be used? If it is accessible externally they should add a low capacitance (~1pF) 8kV protection diode. The chip is OK for 2kV.
3) Its normally good practice to add an additional 10pF cap to the Vio/Vdd bypass caps to act at different frequencies.
4) Pins 1 & 20 are shown as NC but this should also be checked at layout time. If these get connected to GND the chip shouldn’t work.
5) I don’t see any crystal in the design. If they are planning to use the internal RC oscillator of the MCU then they will get 0.5% = 5000ppm at best. The FM needs 100ppm.
6) For lowest current consumption GPIO 1 & 2 should be programmed as outputs and set to 0
schematic مع الصور المرفقة+Si4705) FM RADIO RECEIVER
http://www.keil.com/dd/docs/datashts/silabs/c8051f41x.pdf
هل مهكن مساعدة او إقتراحات بارك اله فيكم
  • Si4704_4705+Datasheet.pdf
    729.6 KB · المشاهدات: 8
    51.6 KB · المشاهدات: 6
