plates deflection
الحالة
مغلق و غير مفتوح للمزيد من الردود.
tarek_abulail
5 سبتمبر 2007
what is the maximum deflection allowed in small sized plate like 400x450 mm with 30mm thickness and as per what code if answer provided
( i dont have arabic keyboard)
hany fraag
11 يوليو 2007
the allowable deflection due to egyption code is span\600
working deflection =(5*w*L^4)\(384*E*I) for simply supported
tarek_abulail
5 سبتمبر 2007
my case is plate fixed with bolts and moment on both sides one perpendicular and one parallel to its plane . its plate connecting steel box beam to concrete wall but its fixed at the side of the beam not at the end
الحالة
