دورات تعليم2007 Solidworks بالفيديو
hardouss
9 يونيو 2006
Info:
This video tutorial covers SolidWorks 2007, and is also applicable to some earlier versions. With its comprehensive, step-by-step approach, this hands-on tutorial will help you master the techniques you need to quickly become productive in SolidWorks.
Created by SolidWorks experts, the video tutorials contain real-world insight and will enable you to draw, design, edit, view and plot in SolidWorks. You will find all of the essential material necessary to successfully create any 2-dimensional (2D) as well as 3-dimensional solid models applicable to any design, architecture, or service industry.​
المحتوى :
Volume 1: Basic
Running Time: 4 hours 40min
01 Basic
02 Interface 43 Overview
03 Tangent Arc 44 Optimizing The Part
04 More on Extrusion eDrawings
05 Sample Hole 45 Overview
06 Complex Extruded Cut 46 Interface
07 Hole Wizard 47 Measure Tool
08 Shell 48 Manipulate Components
09 Section View 49 Section Tool
10 Constant Radius Fillet 50 Mass/Texture
11 Variable Radius Fillet 51 Markup Tool
12 Face Fillet 52 STL Files
13 Full Round Fillet Sheet Metal
14 FilletXpert 53 Bend Allowance
15 Chamfer 54 Applying K-Factor
16 Revolved Feature 55 Bend Allowance/Deduction
17 Revolved Cut 56 Bend Table
18 Mirror Feature 57 Gauge Table
19 Apply Color 58 Creating Base Flange
20 Apply Texture 59 Edge Flange
21 Apply Material 60 Trim Side Bends & Offset
22 Linear Pattern 61 Auto Relief
23 Circular Pattern 62 Custom Relief
24 Draft (Neutral Plane) 63 Miter Flange
25 Draft (Parting Line) 64 Hem Tool
26 Draft (Parting Line with Step) 65 Sketched Bend
27 DraftXpert 66 Closed Corner
28 Rib 67 Jog
29 2D Fillet 68 Break Corner/Corner Trim
30 Mirror Sketching 69 Break Flat Pattern
31 Dynamic Mirror Sketching 70 Tab
32 Trim Entithes 71 Lofted Bend
33 Offset 72 Extruded Cut
34 Selected Contours 73 Simple Hole
35 Sketch Picture 74 Unfold & Fold
36 Assemble 75 Flattened State
37 First 2D Drawing 76 The Design Library
38 Projection View 77 Creating a Library Feature
39 Section View 78 Creating a Forming Tool
40 Dimensions 79 Using a Forming Tool
41 Sample 3Dsketch 80 Forming Tool Comand
42 3D Sketch Plane 81 Insert Bends
82 Vent
83 Fill Pattern
Volume 2: Surface Design
Running Time: 4 hours 41min
01 Curvature Options 32 Funnel Body
02 Zebra Stripes 33 Extrude Surface (Handle)
03 Geometric Continuity 34 Support Sketch (Handle)
04 Extruded Surface 35 Lofted Surface (Handle)
05 Surface Trim 36 Adjusting Handle
06 Boundary Surface Project (Pocket Game)
07 Fillet 37 Circuit Board
08 Project Curve 38 Housing (Solid Body)
09 Thicken 39 Surface (Top Housing)
10 Half Pipe Connection 40 Surface (LCD Opening)
11 Sketch Cross-Connection 41 Surface (Bottom Housing)
12 Pipes Cross-Connection 42 Fillet (Housing)
13 Filled Surface 43 Battery Cover
14 Lofted Surface 44 Create Assembly
15 Swept Surface 45 Creating Shell
16 Swept Twist 46 Edit Battery Cover
17 Swept (Follow Path) 47 Insert Assembly
18 Planar Surface 48 Creating Buttons
19 Face Curves 49 LCD Opening
20 Intersection Curve 50 Top Housing (Details)
21 Offset Surface 51 Dial Pad (Details)1
22 Ruled Surface 52 Dial Pad (Details)2
23 Insert Pictures 53 Dial Pad (Add Fillets)
24 Creating Bottom Surface 54 Buttons Openings
25 Revolved Surface 55 Battery
26 Middle Surface Bodies 56 Add Ribs Top Housing
27 Solid Body 57 Add Ribs Bottom Housing
28 Bathroom Sink 58 Add Bosses (Buttom)
29 Filled Surface 59 Holes (PC Board)
30 Base & Drain Pipe 60 Add Bosses (Top)
31 Funnel (Creating sketch) 61 LCD Openings (Details)
Volume 3: Weldments & Mold Design
Running Time: 1 hour 25min
01 Structural Member
02 End Caps
03 Gusset
04 Filled Bead
05 Trim-Extend
06 Insert Part
07 Custom Profile
08 Sub-Weldment
09 Move-Copy
10 Extruded Cut
11 Configurations
12 Project (3d Sketch)
13 Project 2
14 Cut List (Drawings)
Mold Design
15 Move Face
16 Scale
17 Parting Line
18 Straddle Faces
19 Undercut Detection
20 Parting Line II
21 Shut off Surfaces
22 Parting Surface
23 Tooling Split
24 Core
25 Mold Assembly
26 MoldflowXpress
الشكر لصاحب الرابط.
بالتوفيق.
  • Filefactory links.txt
    720 بايت · المشاهدات: 195
  • Rapidshare links.txt
    1 KB · المشاهدات: 119
amir eleslam
28 سبتمبر 2005
جارى التحميل
جزاك الله كل خير
medozs
5 ديسمبر 2009
شكرررررررر جداااااااااااااا
