Collections of Steel Structure Design Books (Part 2)
إسلام سامي
27 يونيو 2005
TitleURL
Practical Design of Steel Structures
FEMA P-751: Chapter 6: Structural Steel Design
The Behaviour and Design of Steel Structures to EC3, Fourth edition
Building Code Requirements for Structural Concrete (ACI 318-14) & Its Commentary (ACI 318R-14)
Yield Line Analysis of Column Webs
Yield Line Analysis of Web Connection in Direct Tension
Bolted Connections for Rectangular Hollow Sections under Tensile Loading
Dr. Seshu Adluri - Structural Steel Design_Composite Beams
Tips for Avoiding Crane Runway Problems
University of Alberta - Design and Behaviour of Extended Shear Tabs under Combined Loads
BEHAVIOR OF DIAGONAL KNEE MOMENT END-PLATE CONNECTIONS
The Structural Behavior of Connections of Cold-formed Steel Portal Frames
Testing and Design of Bolted Connections in Cold Formed Steel Sections
KIRBY'S TECHNICAL HANDBOOK
COLD-FORMED STEEL DESIGN
Local Bending of Beam Flange due to Single Point Load
Structural Steel Design to Eurocode 3 and AISC Specifications
Structural Design of Buildings
Steelwise - Reinforcing the Point
Steelwise - Economical Weld Design
Steelwise - Choose The Moment
SteelWise- Saying What You Mean
SteelWise- All About Bolts
Steel Structures Design ASD/LRFD - Alan Williams
Standard for Composite Steel Deck
STABILITY ANALYSIS OF PIPE RACKS FOR INDUSTRIAL FACILITIES
Notes on Design of Double-Angle and Tee Shear Connections for Gravity and Seismic Loads
Design of Special Concentric Braced Frames
STEEL BUILDINGS IN EUROPE - Single-Storey Steel Buildings - Part 11: Moment Connections
STEEL BUILDINGS IN EUROPE - Single-Storey Steel Buildings - Part 4: Detailed Design of Portal Frames
Simpler Shear Connections : Design procedures for single-plate shear connections
Significant Changes to the Wind Load Provisions of ASCE 7-10 : An Illustrated Guide
Significant Changes to the Seismic Load Provisions of ASCE 7-10 : An Illustrated Guide
Strength of Welded Joints Under Combined Shear and Out-of-Plane Bending
Seismic Design Provisions of ASCE/SEI 7-2005 - Part 1
Seismic Design Provisions of ASCE/SEI 7-2005 - Part 3
SEISMIC EVALUATION OF PIPE RACK SUPPORTING STRUCTURES IN A PETROCHEMICAL COMPLEX IN IRAN
Seismic design of structural steel pipe racks
SEISMIC DESIGN OF STEEL STRUCTURES
Seismic Design of Concentrically Braced Frames
Seismic Design for Petrochemical Facilities As Per NBCC 2005
C-2011 Standard for Composite Steel Floor Deck-Slabs
Braced Frame Gusset Plate Connections for Seismic Design
SCI P281 : Design of Curved Steel
SCI P252 : Design of Single-Span Steel Portal Frames to BS 5950-1:2000
University of Central Florida - CES 6209 Structural Dynamics- SAP2000 (v.9) : Tutorial of Modal Analysis
Design of Fully Restrained Moment Connections per AISC LRFD 3rd Edition (2001)
SHEAR LAG IN SLOTTED GUSSET PLATE CONNECTIONS TO TUBES
CONNECTION DESIGN IN THE 2005 AISC SPECIFICATION
Analysis, Design & Construction of Steel Space Frames
