كيفية تغيير متعددة حجم النص والخصائص multiple Attribute
hamzasirri
30 أبريل 2011
Is there a way to change multiple (not global) attribute text sizes at once?
We run the block attribute Manager [BATTMAN] command is?.
We consider this command so you can manage the editing of all attributes using the block attribute Manager [BATTMAN] command, drawing on the exist than enhanced attribute editor [EATTEDIT] command to repeat the effort or will be less, so why not?.
The block attribute Manager [BATTMAN] command
1. command line and type BATTMAN, press the [Enter] key.
( or the Ribbon menu on the Home tab > block Panel > attributes, block attribute Manager click the button. )
Block attribute Manager screen is displayed.
2. from the drop-down menu at the top of the screen blocks (B) [â–¼] select the block containing the attributes you want to edit, and click.
3. click the attribute you want to edit from the list, select the.
4. click the [edit] button on the right side.
5. editing of attributes went OK the.
6. click the [apply] button and [OK] will.
In the above operation is one attribute property editing, step 2. -5... Allows to edit the attributes of multiple, repeated, and can deploy multiple same block attributes to bulk edit
[video=youtube;3JTW1Z0yq1E]https://www.youtube.com/watch?time_continue=1&v=3JTW1Z0yq1E[/video]
