إستفسار How to connect the normal fire damper to BMS
Farraj3000
6 مارس 2006
Hi All
Please how to connect the normal fire dampers to BMS. I'm asking about the microswitch in the normal fire damper not the motorized fire damper. Can we connect them to BMS by looping them together in one loop or we should connect each damper direct to the DDC ? Kindly advise
Regards
Muath Farraj​
eyad_rafiq
6 ديسمبر 2014
Hi All
Regards
Muath Farraj​
the fire damper can't be connected to BMS , it is pure mechanical due to it is a spring loaded with a fusible link that can be effected by direct heat only, i have not encountered such a thing .
