شرح أكواد asme التي تهم مهندس الميكانيكا
nile_aster
18 يونيو 2007
اخوتي المهندسين
اليكم بعض الأكواد ASME Codes المهمة التي يحتاجها المهندس الميكانيكي
أرجو أن نستفيد منها جميعا
ASME B16.11 Forged Fittings - Socket Welding - 7.1 MB
ASME B31.2.pdf - 4.1 MB
ASME B31.3 (2001).pdf - 5.7 MB
ASME B31.4 Pipeline Transporation Systems for Liquid Hydrocarbons - 8.2 MB
ASME B31.9.pdf - 4.8 MB
ASME B40_100 Gauges - 5.1 MB
ASME B40_200 Thermometers - Direct Reading - 4.9 MB
ASME MFC_01M Glossary - Measurement of Fluid Flow in Pipes.pdf - 1.9 MB
ASME MFC_02M Measurement of Uncertainty in Fluid Flow in Closed Conduits.pdf - 3.3 MB
ASME MFC_03M Measurement of Fluid Flow in Pipes Using Orifice, Nozzles - 2.7 MB
ASME MFC_04M Measurement of Gas Flow by Turbine Meters.pdf - 976 KB
ASME MFC_05M Measurement of Liquid Flow in Closed Conduit Using Ultrasonic Meter.pdf - 794 KB
ASME MFC_06M Measurement of Fluid Flow in Pipes Using Vortex Meters.pdf - 615 KB
ASME MFC_07M Measurement of Gas Flow by mans Critical Flow Venturin Nozzles.pdf - 1.2 MB
ASME MFC_08M Fluid Flow in Closed Conduits - Connection of Pressure Signal between Primary - 6.8 MB
ASME MFC_11M Measurement of Fluid Flow by Means of Coriolis Mass Flowmeter.pdf - 2.7 MB
ASME MFC_14M Measurement of Fluid Flow by Means of Small Bore Precesion Orifice Meters.pdf - 1.2 MB
ASME MFC_16M Measurement of Fluid Flow in Closed Conduit Using Electromagnetic Flow Meter.pdf - 827 KB
ASME MFC_18M Measurement of Fluid Flow using Variable Area Flow Meters.pdf - 497 KB
ASME PTC 19.3 Temperature Measurement.pdf - 9.4 MB
ASME B16-47 Large Diameter Steel Flanges.pdf - 2.5 MB
ASME B16.20 Metallic Gaskets for Pipe Flanges.pdf - 1.7 MB
ASME B16.21 Non-Metallic Flat Gaskets for Pipe Flanges.pdf - 561 KB
ASME B16.34 Valves-Flanged, Threaded, and Welding End.pdf - 110.2 MB
ASME B16.36 Orifice Flanges.pdf - 955 KB
ASME B16.5-2003 Pipe Flanges - 1.8 MB
ASME B31.5 .pdf - 120 KB
