شيخ الحارة
- إنضم
- 10 أغسطس 2008
- المشاركات
- 359
- مجموع الإعجابات
- 31
- النقاط
- 28
G30, G40, G60 AND G90: UNDERSTANDING
ZINC-BASED COATING WEIGHTS
Zinc-coated, or hot-dipped galvanized, steel is a widely used material in numerous applications
The amount of zinc coating applied over top the core steel for corrosion protection varies depending
upon end-use and specification requirements, and can be controlled and measured to industry standards
Zinc coating weights are listed in the U.S. measurement system in ounces per square foot (oz/ft2), and in the metric system as grams per square meter (g/m2). In both systems, the amount of zinc measured is the
total average for both sides of the core steel.
