لو سمحت اريد الحل الصحيح لهذه الأسئله المتعلقه بالطاقه الشمسيه
mohamad_khaled
13 مايو 2013
If we have this loads
4lamp each one 15 watt
3fan each one 40 watt
1TV 80 watt
1refrigerator 120 watt
1p.c 210 watt
And the lamps will work 3 hours, the fans 6 hours, the TV and p.c 4 hours.
Calculate the following:
A.C average daily energy.
D.C energy.
If we will use inverter 1 Kw and 48 volt calculate the ampere hour.
If we will use a module 100 watt and it’s voltage 16 . 17 volt calculate the number of the module for each string .
Draw design of the system.
Calculate the fill factor for asolar cell which has the following parameters:
V[SUB]oc = [/SUB]0.2 volt
I[SUB] s.c = [/SUB]5.5 mA
V[SUB]max = [/SUB]0.125v
I[SUB]max = [/SUB]3mA
Calculate the maximum and cell efficiency of the cell at an intensity of 200 w/m[SUP]2[/SUP] given that V[SUB]o.c [/SUB]= 0.24 volt and I[SUB]s.c = [/SUB]9mA,
V[SUB]max[/SUB] = 0.14 volt, I[SUB]max [/SUB]= 6mA and the area = 4cm[SUP]2[/SUP] .
Calculate the power output from asolar cell under standard test conditions when efficiency = 16% and filling factor = 0.782
And the aperture area = 4.02*10[SUP]4[/SUP] m[SUP]2[/SUP]
Draw the simple single line diagram of pv system in case of :
on grid
off grid
Draw the p.v and the i.v curve of the module.
