طلب flat spot
c o s t a
11 يونيو 2013
ممكن اعرف ايش هيه الflat spot in rail
وايش تأثيرها
وكيف تنتج في اللحام اللي هوه flushbutt welding
اتمنى الرد العااااااجل
11 أغسطس 2008
A Flat spot, or Wheel flat, is a fault in railroad wheel shape. A flat spot occurs when a rail vehicle's wheelset is dragged along the rail after the wheel/axle has stopped rotating. Flat spots are usually caused by use of the emergency brake, or slip and slide conditions that causes wheels to lock up while the train is still moving. Flat spots are more common in the autumn and winter when the rails are slippery. Flat spots can also be caused by faulty brakes or wheelset bearings.​
  • IIPP - Flat Wheel Detection as a Part of Wayside Train Monitoring Systems.pdf
    338.9 KB · المشاهدات: 11
11 أغسطس 2008
