http://trial.autodesk.com/SWDLDDLM/2..._WIN_32bit.exe
http://trial.autodesk.com/SWDLDDLM/2..._WIN_64bit.exe
لكن ستحتاج عمل التعديل التالي بعد التنصيب:
لمن واجهته مشاكل أثناء تفعيل الاصدار الجديد من AutoCAD Structural Detailing 2013 مثلي فليتبع مايلي..
ASD 2013_Trial expiration date issue_HF Hotfix
Description of Problems
This hotfix will fix the problem with launching AutoCAD Structural Detailing 2013 after trial installation.
Installation Instructions
To install ASD 2013_Trial expiration date issue_HF Hotfix
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following file:
acadbtn.xmx
To replace these files
Restart system.
Navigate to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2013\ASD
Rename the affected original file:
In the product installation folder, right-click the acadbtn.xmx file and rename it to acadbtn.bak
Double click the file:
ASD 2013_Trial expiration date issue_HF.zip
Extract acadbtn.xmx to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2013\ASD
