Sand Control part1
Seham Jalal
5 ديسمبر 2014
Sand production
Sand production is the production of small or large amounts of sand together with the reservoir fluids. These amounts of produced sand vary from a few grams or less per ton of produced reservoir fluid to huge amounts possibly leading to complete filling of the borehole
Some carbonate reservoirs may also produce solids. Unexpectedly produced sand can lead to erosion, loss of integrity and potential fatalities
Conversely, unnecessarily installing sand control can be expensive and detrimental to productivity and reservoir management
The ability to predict when a reservoir will fail and produce sand is fundamental to deciding whether to use down hole sand control and what type of sand control to use
Why do we need Sand control
Well operability Downhole equipment failure
Shut in production due to sanding up Tubing, casing, separators, flow lines
Environmental and Safety Erosion of wellheads and surface piping
Consequences of Sand Production
Production interruptions can be caused by sand plugging the casing, tubing, flow lines and separators
Casing collapse can be caused by changes in overburden pressures and stresses in the formation
Down hole and surface equipment can be destroyed, downtime and replacement costs, spills and in extreme cases a blowout
Disposal of produced sands is costly
محمد الاكرم
24 سبتمبر 2008
شكرا لك
