phenolic acic mortar
phenolic is prepared by mixing solution & powder to form a workable mortar. The recommended ratio of mixing is 1 part solution to 3 parts powder by wt. The ratio will vary depending upon ambient temperature and working conditions. Use clean, dry mixing pan. Take-out required quantity of solution and add powder to it, slowly and start mixing until you get smooth paste, free from loose powder. Do not prepare more
material, then can be used within 20-30 minutes.
what is solution
ايه مكونات resin ?
what is solution
ايه مكونات resin ?
