Bentley STAAD.Pro V8i (SELECTSeries 5) 20.07.10.65 - الرابط من رفعى
علاء عبدالحليم
2 مايو 2007
Bentley STAAD.Pro V8i (SELECTSeries 5) 20.07.10.65 | 726.2 Mb
Bentley Systems Incorporated, the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released an update to STAAD.Pro V8i (SELECTSeries 5) 20.07.10.64, is the structural engineer's software choice for steel, concrete, timber, aluminum and cold-formed steel structure design of low and high-rise buildings, culverts, petrochemical plants, tunnels, bridges, piles, aquatic structures and much more! In July this year developer released a new version of STAAD.Pro V8i SELECTseries 5 (20.07.10.64), which included a number of enhancements principally with the addition of Russian and Canadian design codes and also designed for use on Russian projects. However despite extensive testing, after the release we were notified that some of these enhancements unfortunately included a number of errors. We are pleased to announce that we have been able to address the issues and posted a new build on the Bentley SELECT server and recommend that this be downloaded and the earlier versions of STAAD.Pro be updated with this version. The Revision History document included in the ReadMe outlines all the issues that have been addressed which can be summarized as: - Russian Steel Design Correct variable initialisation to support multiple member design Improved pagination Design results available in the GUI - Russian Wind Design Correction for use with the Basic solver - Canadian Steel Design S-16-01 Class 4, slender section effective areas for angle profiles - AISC 360-10/05 Compression capacity and torsion capacity for circular hollow sections Double angle section design Designs governed by slenderness - IS 1893 Command processing updates - Advanced Cable Analysis Vertical cable analysis - Concrete Mode Support for changing member dimensions after an initial design - Connection Mode Support of double angle sections for bracing About Bentley Systems, Incorporated Bentley is the global leader dedicated to providing architects, engineers, geospatial professionals, constructors, and owner-operators with comprehensive software solutions for sustaining infrastructure. Bentley Systems applies information mobility to improve asset performance by leveraging information modeling through integrated projects for intelligent infrastructure. Its solutions encompass the MicroStation platform for infrastructure design and modeling, the ProjectWise platform for infrastructure project team collaboration and work sharing, and the AssetWise platform for infrastructure asset operations - all supporting a broad portfolio of interoperable applications and complemented by worldwide professional services. Founded in 1984, Bentley has more than 3,000 colleagues in 50 countries, more than $500 million in annual revenues, and since 2003 has invested more than $1 billion in research, development, and acquisitions. Name: Bentley STAAD.Pro V8i Version: (SELECTSerias 5) 20.07.10.65 Home: www.bentley.com Interface:english OS: Windows XP / Vista / Seven / 8
رابط التحميل
http://www.gulfup.com/?g4uLDP
