Pipe Flow Expert
أفضل وأسهل برنامج متخصص فى تصميم وتحليل شبكات الانابيب Pipelines
مع حسابات ونتائج الـ Flow و الـ Pressures
ورسم مخطط تصميم الشبكات
وإنشاء تقارير للنتائج والتصميم
features include مميزات البرنامج
● An Intuitive User Interface that is best-in-class & easy to use
● Isometric 3D drawing and standard 2D piping layouts
● Customized PDF reports - generate professional results documentation
Robust Calculation Engine that will solve complex pipe networks
● Pressure Loss calculated using the Darcy-Weisbach method
● Friction Factors calculated using the Colebrook-White equation
● Modelling of up to 1000 pipes in the full version.
● A Fluid Database with common liquid and gas data
● A Pipe Database with common pipe materials and sizes
● A Fittings Database with common valve and fitting data
