بركات العنزي
- إنضم
- 16 أكتوبر 2014
- المشاركات
- 1
- مجموع الإعجابات
- 0
- النقاط
- 0
Profile
Welcome to WELD DOMAIN is a service oriented Organization promoted by Well-trained & graduated from Jubil Technical institute A Royal Commission undertaking KSA Jubil .Mr. Bhakat.H AL_Qassim .
We are pursuing 21st century vision of becoming a true global welding solutions leader that can please its customers throughout Saudi Arabia by means of its innovative welding products and services.
We are among top-notch manufacturer of a wide assortment of Welding Electrode in Asia biggest jubil industrial in kingdom of Saudi Arabia . Our entire Product is developed by a well-qualified and sincere team of professionals, using latest machines and technologies. With an objective to maintain quality standards, all our products are properly tested at our quality inspecting laboratory at varied parameters, before the final delivery. The offered range of electrodes find their application in steel construction, machine building, ship building, general repairs and maintenance. Customer can avail following range of electrodes from us E6013, E7018, E6010,SS Electrode 308L,309L,310,312& hard facing 250, 350, 550 for various welding purposes.
we seek to secure three core capabilities: product leadership, market leadership, and people-centered leadership. This is an ambitious vision which will be achieved through the commitment and participation of every employee within the Weld domain. Our sense of responsibility, integrity and respect being the core values; we aspire to be the supplier of choice, by offering premium products and services, backed up with unrivalled service packages.
Resources
Our state of the art factory is located in Jubil Industrial institute. Under Royal commission .
We possess modern R&D unit and housing lab in JTI. We are using EQ grade wire and export quality chemicals are used in the manufacturing process.
We carry out flow less production of 1 ton units per day.
Quality Assurance
To ensure superlative quality of our range ,we focus on procuring raw materials with extensive care and under the guidance of our testing laboratory facilities to ensure that we the best welding electrode that are stringently quality tested as per AWS standard.
Our range of welding electrode are manufactured by export quality of raw materials procured from different parts of the world . Which are procured from reliable vendors in the market .
For this we can provide third party certificate also.
Client satisfaction.
Delivering 100% client satisfaction is our foremost objective. We are offering quality range ,protected from moisture free &safe packaging and timely deliveries for the client at market leading prices.
Our trained technician and skilled staff are committed to make available the best welding electrode in KSA.
PRODUCT.
WE USE HIGH QUALITY LOW HYDROGEN ,LOW CARBON EQ GRADE MILD STEEL.FOR MANUFACTURING WELD DOMAIN WELDING ELECTRODE .
USING OUR ELECTRODE THE WELD METAL ACQUIRES TENSILE STRENGTH, CORROSION RESISTANCE AND HIGH RELIABLITY.
OUR EXCLUSIVE RANGE OF WELD DOMAIN ELECTRODE HAVE HIGH DEMAND AS WELL AS WIDE ACCEPTANCE IN JTI UNDER ROYAL COMMISION .
PRODUCT RANGE
WELDING ELECTRODE IS A HIGH QUALITY PRODUCT &ALSO A WIDE RANGE OF WELDING ELECTRODE AVAILABLE AT OUR INDUSTRIES FOR VARIOUS TYPE OF ELECTRODE.
· MILD STEEL ELECTRODE
· LOW HYDROGEN ELECTRODE
· HIGH TENSILE LOW HYDROGEN ELECTRODE.
· PIPE WELD ELECTRODE
WE ARE UNDER R&D FOR FURTHER EXPANSION OF OTHER PRODUCTS LIKE
· CAST IRON ELECTRODE.
· HARDFACING ELECTODES.
· STAINLESS STEEL ELECTRODE.
· MAINTENCE ELECTRODE
· CUTTING &GAUGING ELECTRODES.
WE HAVE OUR CUSTOMER CARE SERVICE 24 HOUR ON LINE .96654700718
WELDOMIN E 6013
Weldomain E 6013. Its Low carbon steel electrode with Titanium coating and can be used on AC or DC. It has excellent technological properties. The Arc is stable, less spatter less slag Viscosity is moderate. It can be used freely. The slag removal easy. The welded seam is smooth and fine easy to restrike the arc, suitable for welding sheet metal structure made of Low carbon steel , such as ships, Vehicles, building & general machinery.
Like structure building
WELDOMIN E 7018
Weldomain E 7018 has Excellent strength and toughness properties. Metal recovery about 120% with Low hydrogen type of electrode .Suitable for welding in steel construction, Boiler making ,container making ,vertical construction shiping as well as buffer layers when building up to high carbon steel
WELDOMIN E 6010
Weldomain E 6010 cellulose coated electrode for vertical down welding of large Properties diameter piplines. Especially recommended for root run welding Highly economical compared with vertical up welding.
Resources
Quality Assurance
PRODUCT.
PRODUCT RANGE
WELDOMIN E 6013
WELDOMIN E 7018
WELDOMIN E 6010
