ستندرات الحديد حسب النظام الالماني din
غظنفر العراقي
11 مايو 2013
اخوان محتاج ستندرات الحديد خسب النظام الالماني din الي يملكها بلكي يرفعها على الموقع ضروري جدا:87:
مع فائق الشكر والتقدير
11 أغسطس 2008
steel grades
Standard steel grades, comparison,
designations and codes
  • Ruukki-Hot-rolled-steels-Standard-steel-grades-comparison-designation-and-codes1.pdf
    639.5 KB · المشاهدات: 184
11 أغسطس 2008
Comparison of standards
  • tlb_normenvergleich_e_08092011.pdf
    337.4 KB · المشاهدات: 82
11 أغسطس 2008
International Material Grade Comparison Table
International Material Grade Comparison Table​
  • InternationalMaterialGradeComparisonTable.pdf
    57.4 KB · المشاهدات: 46
11 أغسطس 2008
Steel and Alloy Numbers Steel classification according to EN 10027-2. Designation systems for steel
[SIZE=+1]1.0XXX[/SIZE]Non-alloy steels
Number = 1.00XX Base steels
Number = 1.01XX Quality steel (General structural steels with Rm < 500 MPa )
Number = 1.02XX Other structural steels (Not intended for heat treatment with Rm < 500 MPa )
Number = 1.03XX Steels with average C < 0,12% or Rm < 400 MPa
Number = 1.04XX Steels with average 0,12% =< C < 0,25% or 400 MPa = < Rm < 500 MPa
Number = 1.05XX Steels with average 0,25% =< C < 0,55% or 500 MPa =< Rm < 700 MPa
Number = 1.06XX Steels with average C >= 0,55% or Rm >= 700 MPa
Number = 1.07XX Steels with higher P or S content
[SIZE=+1]1.0XXX[/SIZE]Alloy Steels
Number = 1.08XX Steels with special physical properties
Number = 1.09XX Steels for other applications
[SIZE=+1]1.1XXX[/SIZE]Non-alloy special steels
Number = 1.10XX Steels with special physical properties
Number = 1.11XX Structural pressure vessel and engeneering steels with C < 0,5%
Number = 1.12XX Structural pressure vessel and engeneering steels with C > = 0,5%
Number = 1.13XX Structural pressure vessel and engeneering steels with special requirements
Number = 1.14XX -
Number = 1.15XX Tool steel
Number = 1.16XX Tool steel
Number = 1.17XX Tool steel
Number = 1.18XX Tool steel
Number = 1.19XX -
[SIZE=+1]1.2XXX[/SIZE]Alloy Tool Steels
Number = 1.20XX Cr
Number = 1.21XX Cr-Si, Cr-Mn, Cr-Mn-Si
Number = 1.22XX Cr-V, Cr-V-Si, Cr-V-Mn, Cr-V-Mn-Si
Number = 1.23XX Cr-Mo, Cr-Mo-V, Mo-V
Number = 1.24XX W, Cr-W
Number = 1.25XX W-V, Cr-W-V
Number = 1.26XX W excluding groups 24, 25 and 27
Number = 1.27XX With Ni
Number = 1.28XX Other
Number = 1.29XX -
[SIZE=+1]1.3XXX[/SIZE]Alloy Miscellaneous Steels
Number = 1.30XX -
Number = 1.31XX -
Number = 1.32XX High speed steel with Co
Number = 1.33XX High speed steel without Co
Number = 1.34XX -
Number = 1.35XX Bearing steels
Number = 1.36XX Materials with special magnetic properties without Co
Number = 1.37XX Materials with special magnetic properties and with Co
Number = 1.38XX Materials with special physical properties without Ni
Number = 1.39XX Materials with special physical properties and with Ni
[SIZE=+1]1.4XXX[/SIZE]Stainless and Heat Resisting steels
Number = 1.40XX Stainless steel with Ni < 2.5 % without Mo, Nb and Ti
Number = 1.41XX Stainless steel with Ni < 2.5 % and Mo but without Nb and Ti
Number = 1.42XX -
Number = 1.43XX Stainless steel with Ni >= 2.5 % without Mo, Nb and Ti
Number = 1.44XX Stainless steel with Ni > = 2.5 % with Mo but without Nb and Ti
Number = 1.45XX Stainless steels with special additions
Number = 1.46XX Chemical resistant and high temp Ni alloys
Number = 1.47XX Heat resistant steels with Ni < 2.5 %
Number = 1.48XX Heat resistant steels with Ni > = 2.5 %
Number = 1.49XX Materials with elevated temperature properties
[SIZE=+1]1.5XXX[/SIZE]Structural, pressure vessel and engineering steels
Number = 1.50XX Mn-Si-Cu
Number = 1.51XX Mn-Si, Mn-Cr
Number = 1.52XX Mn-Cu, Mn-V, Si-V, Mn-Si-V
Number = 1.53XX Mn-Ti, Si-Ti
Number = 1.54XX Mo, Nb, Ti, V, W
Number = 1.55XX B, Mn-B Mn < 1.65 %
Number = 1.56XX Ni
Number = 1.57XX Cr-Ni with Cr < 1.0 %
Number = 1.58XX Cr-Ni with 1.0 % =< Cr < 1.5 %
Number = 1.59XX Cr-Ni with 1.5 % =< Cr < 2 %
[SIZE=+1]1.6XXX[/SIZE]Structural, pressure vessel and engineering steels
Number = 1.60XX Cr-Ni with 2 % =< Cr < 3 %
Number = 1.61XX -
Number = 1.62XX Ni-Si, Ni-Mn, Ni-Cu
Number = 1.63XX Ni-Mo, Ni-Mo-Mn, Ni-Mo-Cu, Ni-Mo-V, Ni-Mn-V
Number = 1.64XX -
Number = 1.65XX Cr-Ni-Mo with Mo < 0.4 % + Ni < 0.2 %
Number = 1.66XX Cr-Ni-Mo with Mo < 0.4 % + 2.0 % =< Ni < 3.5 %
Number = 1.67XX Cr-Ni-Mo with Mo < 0.4 % + 3.5 % =< Ni < 5 %, or Mo >= 0.4 %
Number = 1.68XX Cr-Ni-V, Cr-Ni-W, Cr-Ni-V-W
Number = 1.69XX Cr-Ni except groups 57 to 68
[SIZE=+1]1.7XXX[/SIZE]Structural, pressure vessel and engineering steels
Number = 1.70XX Cr, Cr-B
Number = 1.71XX Cr-Si, Cr-Mn, Cr-Mn-B, Cr-Si-Mn
Number = 1.72XX Cr-Mo with Mo < 0.35 % , Cr-Mo-B
Number = 1.73XX Cr-Mo with Mo >= 0.35 %
Number = 1.74XX -
Number = 1.75XX Cr-V with Cr < 2.0 %
Number = 1.76XX Cr-V with Cr >= 2.0 %
Number = 1.77XX Cr-Mo-V
Number = 1.78XX -
Number = 1.79XX Cr-Mn-Mo, Cr-Mn-Mo-V
[SIZE=+1]1.8XXX[/SIZE]Structural, pressure vessel and engineering steels
Number = 1.80XX Cr-Si-Mo, Cr-Si-Mn-Mo, Cr-Si-Mo-V, Cr-Si-Mn-Mo-V
Number = 1.81XX Cr-Si-V, Cr-Mn-V, Cr-Si-Mn-V
Number = 1.82XX Cr-Mo-W, Cr-Mo-W-V
Number = 1.83XX -
Number = 1.84XX Cr-Si-Ti, Cr-Mn-Ti, Cr-Si-Mn-Ti
Number = 1.85XX Nitriding steels
Number = 1.86XX -
Number = 1.87XX Steels not for heat treatment by user
Number = 1.88XX High strength weldable steels not intended for heat treatment by user
Number = 1.89XX High strength weldable steels not intended for heat treatment by user
[SIZE=+1]1.9XXX[/SIZE]Non-alloy Quality steels
Number = 1.90XX Base steels
Number = 1.91XX Quality steel (General structural steels with Rm < 500 MPa )
Number = 1.92XX Other structural steels (Not intended for heat treatment with Rm < 500 MPa )
Number = 1.93XX Steels with average C < 0,12% or Rm < 400 MPa
Number = 1.94XX Steels with average 0,12% =< C < 0,25% or 400 MPa = < Rm < 500 MPa
Number = 1.95XX Steels with average 0,25% =< C < 0,55% or 500 MPa =< Rm < 700 MPa
Number = 1.96XX Steels with average C >= 0,55% or Rm >= 700 MPa
Number = 1.97XX Steels with higher P or S content
[SIZE=+1]2.XXXX[/SIZE]Alloy
Number = 2.XXXX
