مساعدة في حل مسائل مادة Properties of Petroleum Reservoir Fluids
بو جاسم 21
30 ديسمبر 2013
قعدت ادور حل حق كتاب حث المسائل ماحصلت
ومافي حل حق المسائل مادري اذا كان في ولا لا
عندي جم مسأله ابي الفكرة اذا ماعليكم امر لان ماقدرت احلهم وعندي فاينل ف محتاج مساعدة اذا ماعليكم امر هذه المسائل
3 مسائل
You have just discovered a petroleum reservoir. Initial testing of the well produced 76 barrels of 18.2[SUP]o[/SUP] API stick tank oil and 14.1 Mscf of gas in 24 hours. What is the solution gas oil ratio?(
______________________________________________________________
A tank contains methane at 1000 psia and 140 F with a z factor of0.9. Another tank of equal volume contains ethane at 500 psia and 140 F with a z factor of 0.7. The two tanks are connected, the gases are allowed to mix, and the temperature is restored to 140 F. Calculate mole fractions for both ethane and methane.
The 1 lbm of the gas in problem 1, is contained in a cubic tank within a bigger cubic tank as shown in Figure 1. The bigger tank length is double the smaller tank length. The big tank contains a natural gas at 2000 psia and temperature of150 [SUP]o[/SUP]F. Calculate the natural gas mole number.
