CSI SAP2000 v16.0.0 - الرابط من رفعى
علاء عبدالحليم
2 مايو 2007
CSI SAP2000 v16.0.0 | 361.4 mb
SAP2000 is general-purpose civil-engineering software ideal for the analysis and design of any type of structural system. Basic and advanced systems, ranging from 2D to 3D, of simple geometry to complex, may be modeled, analyzed, designed, and optimized using a practical and intuitive object-based modeling environment that simplifies and streamlines the engineering process.
The SAPFire Analysis Engine integral to SAP2000 drives a sophisticated finite-element analysis procedure. An additional suite of advanced analysis features are available to users engaging state-of-the-art practice with nonlinear and dynamic consideration. Created by engineers for effective engineering, SAP2000 is the ideal software tool for users of any experience level, designing any structural system.
Integrated modeling templates, code-based loading assignments, advanced analysis options, design-optimization procedures, and customizable output reports all coordinate across a powerful platform to make SAP2000 especially useful for practicing professionals.
SAP2000 is also an excellent medium for education.
SAP2000 version 16 Enhancements:
Significant enhancements included in SAP2000 v16.0.0, besides bug fixes:
- Improved graphics performance
- Display of multiple grid systems at the same time
- New steel frame design code AISC 360-10
- New steel frame design code NTC 2008
- New concrete frame design code ACI 318-11
- New concrete frame design code NTC 2008
- New concrete frame design code NZS 3101-06
- New concrete frame design code RCDF 2004
- New concrete frame design code Hong Kong CP 2013
- Enhanced beam-column capacity check for concrete frame design using Eurocode 2-2004
- Stiffness modifiers from the AISC 360 steel frame design direct analysis method are now available in the database table for assigned frame property modifiers
- New wind, seismic, and response-spectrum lateral loads for code IBC 2012
- New wind lateral loads for code AS/NZS 1170.2-2011
- New wind, seismic, and response-spectrum lateral loads for code NTC 2008
- New wind, seismic, and response-spectrum lateral loads for codes TSC 2007 and TS 498-97
- New response-spectrum lateral loads code AASHTO 2012
- New assignment to control area loads transferred to frames
- New hybrid U-girder frame section property
- New built-in ASTM bridge steel materials
- Chinese concrete material and design updated to use characteristic strength rather than grade
- New link property for modeling triple-pendulum bearings
- External tendons can now be modeled under user control
- Plotting of tendon loads, losses, and axial-force response has been enhanced
- Ground displacement loading now applies to single-joint links, including distributed spring supports, as well as to springs and restraints
- Multiple mass sources can be defined for modeling alternative dynamic behavior
- The undeformed shape can now be viewed for various stages of staged construction load case without running the analysis
- Response output for staged-construction load cases now is labeled with the stage and step within the stage
- Shear stress, von Mises stress, and principal stress response is now available for certain frame sections
- Shell stresses can now be displayed normalized by material strength
- Bearing pressure on shells from area springs can now be displayed
- Display of frame-design D/C ratios can be limited by a specified threshold value
- Verification suites are now provided for steel and concrete frame design by most codes
- New Open API functions to define section-cuts
- New Open API functions to define external load cases for frame results
- New Open API functions to get detailed steel frame design results for certain codes
- Customizable keyboard shortcuts for menu commands
- Support for the import and export of files using the IFC 4 format
- Licensing will now support web-activation and virtual servers
- Simplified installation using the CSI Installation Wizard
- Other minor enhancements
رابط التحميل
http://www.gulfup.com/?J6CqSl
ahmed7788
31 مايو 2010
جزاكم الله عنا خير الجزاء ونفع الله بنا وبكم
