م.عبدالكريم عوضه
- إنضم
- 12 سبتمبر 2013
- المشاركات
- 4
- مجموع الإعجابات
- 1
- النقاط
- 0
A single plate clutch (both sides effective) is required to transmit 26.5 kW at 1600 r.p.m. The outer diameter of the plate is limited to 300 mm and intensity of pressure between the plates is not to exceed 68.5 kN/m2. Assuming uniform wear and a coefficient of friction 0.3, show that the inner diameter of the plates is approximately 90 mm
