الطاقة الشمسية وانظمة التكيف
md beida
18 أبريل 2011
من احسن ما طالعة في مجاله يحتوي الكثير الكثير من المفيد ويمتاز بالبساطة وصغر الحجم وأتمنى ان يستفيد منه احد
و
الله المستعان
Solar Air-Conditioning Systems
Focus on components and their working principles
Nathan Rona
Table of contents
1. Introduction...............................................................................1
1.1 General Background............................................................................1
1.2 Report background, aims and coverage............................................2
1.3 Report structure...................................................................................2
1.4 Definitions and concepts.....................................................................3
2. Components..............................................................................4
2.1 Distribution...........................................................................................5
2.1.1 All-air-systems.................................................................................5
2.1.2 Hydronic systems............................................................................6
2.1.3 Decentralized systems....................................................................6
2.2 Processing (Refrigeration and dehumidification)............................8
2.2.1 Mechanical and Electric Heat Pumps............................................8
2.2.1.1 Vapor Compression System....................................................8
2.2.1.2 Stirling cooling........................................................................11
2.2.1.3 Brayton refrigeration cycle ....................................................13
2.2.1.4 Thermoelectric modules.........................................................14
2.2.2 Heat engines.................................................................................16
2.2.2.1 Rankine power cycle..............................................................16
2.2.2.2 Stirling engine........................................................................19
2.2.2.3 Brayton power cycle...............................................................21
2.2.2.4 Thermoelectric generator.......................................................22
2.2.3 Thermal Heat Pumps....................................................................23
2.2.3.1 Carré cycle absorption heat pump.........................................24
2.2.3.2 Diffusion (Platen Munters) absorption cycle...........................39
2.2.3.3 Open absorption cycle ..........................................................42
2.2.3.4 Solid sorption heat pumps.....................................................47
2.2.3.5 Ejector (steam jet) cycle.........................................................51
2.2.4 Evaporative cooling ......................................................................54
2.2.4.1 Direct evaporative cooling......................................................55
2.2.4.2 Indirect evaporative cooling ..................................................56
2.2.4.3 Indirect-direct evaporative cooling .......................................56
2.2.5 Desiccant dehumidification..........................................................57
2.2.5.1 Solid desiccant dehumidification ...........................................57
2.2.5.2 Liquid desiccant dehumidification .........................................59
2.3 Solar energy collection .....................................................................62
2.3.1 PV. (Photovoltaic) cells.................................................................63
2.3.2 Thermal collectors ........................................................................66
2.3.2.1High temperature collectors....................................................71
2.3.2.2 Medium-low temperature Hot water collectors.......................77
2.3.2.3 Medium-low temperature Air collectors..................................88
2.4 Heat rejection......................................................................................89
2.4.1 Air cooled systems........................................................................89
2.4.2 Water cooled systems...................................................................90
2.5 Storage................................................................................................94
2.5.1 Sensible heat storage...................................................................94
2.5.2 Latent heat storage.......................................................................95
2.5.3 Chemical storage..........................................................................95
2.5.4 Electrical storage...........................................................................96
3. Systems...................................................................................97
2.27 Double effect H20/LiBr chiller............................................................................32
2.28 COP as for single-, double.- and triple-effect H2O/LiBr absorption chillers.......33
2.29 GAX-cycle...........................................................................................................34
2.30 Schematic GAX-cycle..........................................................................................35
2.31 Cooling COP for various NH3/H20 cycles.........................................................35
2.32 Temp.-press.-conc. diagram of saturated LiBr-water solutions...........................37
2.33 Platen Munters absorption system.......................................................................39
2.34 Principle of AAAC ..............................................................................................41
2.35 Solar generator open absorption system..............................................................43
2.36 Open generator with spray chamber....................................................................44
2.37 Solar generator with glass covering.....................................................................45
2.38 Schematic description of the difference between absorption and adsorption .....47
2.39 Two chamber adsorption chiller...........................................................................48
2.40 Claperyron diagram for solid sorption cycle........................................................49
2.41 Switching schedule for a 4-bed adsorption chiller over two cycles.....................49
2.42 COP of ad/absorption chiller ...............................................................................50
2.43 Schematic ejector refrigeration cycle...................................................................51
2.44 Cross section of an ejector ..................................................................................51
2.45 COP ejector refrigeration system.........................................................................52
2.46 Multistaged ejectors.............................................................................................53
2.47 Evaporative cooling in Mollier chart...................................................................54
2.48 Spray humidifier...................................................................................................54
2.49 Direct evaporative cooling...................................................................................55
2.50 Indirect evaporative cooling.................................................................................56
2.51 Indirect-direct evaporative cooling......................................................................56
2.52 Schematic diagram of a desiccant wheel..............................................................57
2.53 State changes for dehumidification with desiccant wheel...................................57
2.54 Schematic diagram of a desiccant bed dehumidification system.........................58
2.55 Schematic diagram of a liquid desiccant dehumidifier........................................59
2.56 Liquid desiccant, low flow rate, internally cooled, falling film dehumidifier.....60
2.57 Attenuation of solar radiation as it passes through the atmosphere.....................62
2.58 Principles of a silicon photovoltaic cell...............................................................63
2.59 Solar cell, module and array.................................................................................63
2.60 Tracked PV. Array containing16 panels..............................................................64
2.61 Power output for a tracked and a non tracked array.............................................64
2.62 Principles of concentrating collectors..................................................................64
2.63 Typical efficiency plot (for a flat CPC-collector) resulting from two models.....70
2.64 Schematic heliostat field......................................................................................71
2.65 Solar Two.............................................................................................................71
2.66 Central receivers...................................................................................................72
2.67 Schematic representation of tower-reflector system............................................72
2.68 Cross-sectional drawing of a solar fiber-optic mini-dish.....................................73
2.69 Schematic top view of a glazed module of circular mini-dishes.........................73
2.70 Schematic mini-dishes solar field .......................................................................73
2.71 Schematic dish collector......................................................................................74
2.72 SAIC 20 kW dish Stirling System........................................................................74
2.73 Combined receiver and stirling heat engine.........................................................74
2.74 Schematic parabolic trough collector...................................................................75
2.75 Parabolic trough collectors of different sizes.......................................................75
2.76 Evacuated receiver for the LS2 parabolic trough collector..................................75
2.77 Efficiency of a parabolic trough collector............................................................7
2.78 Schematic (“Dewar-China”)evacuated tube collector ........................................77
2.79 Evacuated tube module with 16 tubes..................................................................77
2.80 Evacuated tubular collectors around 1980...........................................................77
2.81 Schematic drawing of a heat pipe........................................................................78
2.82 Evacuated heat pipe collector construction..........................................................78
2.83 “All-glass-design” evacuated tubular collectors..................................................79
2.84 “Water-in-glass” system.......................................................................................80
2.85 Ray trace diagrams of the tubular CPC collector at three incidence angles.......80
2.86 Tubular collector with diffuse flat white reflector...............................................81
2.87 Top view of the SK-400 high temperature CPC collector...................................81
2.88 Measured efficiencies for two evacuated tubular collectors................................82
2.89 Incident angel modifier for two evacuated tubular collectors..............................82
2.90 Schematic flat plate collector...............................................................................83
2.91 Roof integrated flat plate collectors.....................................................................83
2.92 Common types of absorber plates........................................................................83
2.93 Solar thermal flat collector envisioned for 2010..................................................84
2.94 Cross section of a flat plate CPC collector with honeycomb TIM......................84
2.95 Typical efficiency & incident angel modifier flat plate coll. from 1980 to2010..85
2.96 Measured effi. for a flat plate TIM collector comp. with two evacuated tubular.85
2.97 ICS-collector with TIM and CPC-reflector..........................................................86
2.98 Schematic diagram of a nonconvecting solar pond..............................................87
2.99 Cross sections of typical air collectors.................................................................88
2.100 Air-cooled condenser.........................................................................................89
2.101 Horizontal shell-and-tube condenser..................................................................90
2.102 Schematic drawing of a open cooling tower and an evaporative condenser....91
2.103 Relationship water and air's wet bulb temperature in a cooling tower ............92
2.104 Psycrometric analysis of air passing through a cooling tower...........................92
3.1 Primary energy factor as function of COP.............................................................99
3.2 Schematic Photovoltaic-air-conditioning systems...............................................101
3.3 Schematic heat driven solar air-conditioning systems.........................................103
3.4 COP, collector efficiency and COPsol as func. of operation temperature.............104
3.5 Duplex Rankine cycle solar air-conditioning system...........................................105
3.6 Schematic high efficient solar cooling plant as suggested by Gordon (2000).....107
3.7 Schematic Rankine heat-engine absorption-chiller cycle hybrid.........................107
3.8 Schematic solar driven desiccant cooling system................................................108
3.9 Pennington all-desiccant cycle. Schematic and in a Mollier chart .....................109
هذه بعض من محتويات الكتاب اذا عجبك حمل وإلا صلي على خير البشر وادعيلي
:3:
nofal
12 مايو 2005
جزاك الله خيرا .
فرج فركاش
29 يونيو 2008
مشكور ياريت لو عندك اى كتب ثانيه عن نفس الموضوع وايضا ashrae hand book of fundamentals 1985
عاطف 58
23 ديسمبر 2011
جزاك الله خير - وحفظك وأفاض عليك.
فرج فركاش
29 يونيو 2008
مشكور ياريت لو عندك اى كتب ثانيه عن نفس الموضوع وايضا ashrae hand book of fundamentals 1985​
md beida
18 أبريل 2011
مشكور يا اخي بصراحة المنشورات في المجال تتسم بقلتها وانا ابحث عنها ايضا لذا سوف اجدد طلبك لعل
الله يساعدنا ونجد من يملك منها شيئا وأجره على الله
م اسعد ميكا
4 نوفمبر 2012
شكرا جزيلا لك على الجهد و المثابرة و الشرح الوافي
دمتم بخير
md beida
18 أبريل 2011
دمتم بخير
الفضل يعود الى الله
مهندس اسعد
اهلا وسهلا بك في هذا الصرح العملاق وان شاء الله تفيدنا ونفيدوك والله يكون فعونك
