أرجو من المهندسين مساعدتي في الحل
Problem 1Using the CHEMKIN spreadsheet to calculate the flame temperatures of the premixed mixture CH4 –air (initial temperature set as 298.15K) with equivalence ratio φ = 0.5, 1.0 and 1.5.
Problem 2
A mixture of hydrogen and air initially at 25°C and 1 atm pressure is burned in a constant-pressure adiabatic process in which the adiabatic flame temperature is 2,800K. Assuming complete combustion in all calculations determine (a) volume of products to the volume of reactants; (b) molar AF ratio, kmol air/kmol fuel; (c) excess air required, %; and (d) equivalence ratio for the process.
Problem 3
, Calculate the enthalpy, entropy, Gibbs function G and Helmhotz function A for
the following species at pressures between 5 – 20 atms and temperatures between 500 K –
1500 K with the temperature step of 10 K. (using the spreadsheet, using the real gas formula)
C(s)/graphite
CH4
CH3OH
C2H4
C4H10/therm
C4H10/pitz
CO
CO2
H2
HCl
H2O
H2O(l)
N2
O2
CH3
OH
C2H2
HCN
Problem 2
Problem 3
C(s)/graphite
CH4
CH3OH
C2H4
C4H10/therm
C4H10/pitz
CO
CO2
H2
HCl
H2O
H2O(l)
N2
O2
CH3
OH
C2H2
HCN
