دورات في ال autocad civil 3d 2012 بالرياض (طرق – مساحة – حساب كميات )
EMADAREF1234
11 يناير 2011
يسرني ان اعلن عن بداية مجموعة من الدورات في ال
مدرب معتمد من شركة AUTODESK دورة تدريبية على البرنامج بالرياض تمكنك فى النهاية من تصميم الطرق و القيام بكل الاعمال المساحية وحساب الكميات
وعلي الراغبين بتسجيل الاسماء مراسلتي علي هذه الموقع او علي
mobile :- 0582244824
riyadh ksa
مكونات الدورة
CIVIL 3D COURSE OUTLINE
1) survey database
· creating database
· creating prefix and suffix
· creating line work
2) points
· creating ,editing and organizing points
· settings and styles
· description keys
· point groups
· points applications
· point exporting
· points output
2) surfaces
· surface definitions
· creating & editing surfaces
· surfaces properties
· surface from Google earth
· surface analyzing
3) alignment
· creating alignment
· alignment geometry
· alignment editing
· offset alignment
· alignment labels and styles
4) profiles
· profile views creating and styles
· profile view properties
· layout profile creating
· superimpose profiles
· editing profile styles
· profile bands
· profile geometry
5) GRADING
· grading creation tools
· Explain the basic concepts of grading.
· Create spot elevations and feature lines.
· Edit grading criteria.
· Create grading objects and grading groups.
· Create a design surface.
· Use styles and labels to create a basic grading plan
· Explain how you calculate earthwork volumes.
6) Roadway Assemblies and Corridors
Create assemblies and subassemblies.
· subassembly input and target parameters.
· create a corridor model and list its components.
· Create a corridor surface.
· Create an assembly that consists of lanes, shoulders, guardrails, and match slopes
· Map corridor targets
· View and edit corridor sections.
· code set style assigns rendered material styles to corridor links.
7) intersections
8) Roadway Plan Production
Create view frames in a view frame group.
· Create all plan and profile sheets in the current drawing.
· Create all plan and profile sheets in a new drawing.
· Create all plan and profile sheets in individual drawings.
· Use the AutoCAD Sheet Set Manager to manage the sheets.
9) Cross Sections and Quantities
· Create and edit sample lines.
· Modify the sample line group properties and add additional section data
· Calculate the earth cut and fill and pavement structure quantities for a c
· Create quantity reports that display quantity calculations.
· Create a quantity report in a table and a quantity report in a web browse
· Create section views from sample lines.
· Create multiple section views.
10 )Pipe Design
steps for creating pipe networks.
· Create a storm sewer pipe network.
· Draw a pipe network in profile view.
· Edit the pipe network.
· Label pipe networks.
· Design a storm sewer network that includes pipe sizes and invert elevations
