الثقب الأفقي
heno9
25 أغسطس 2011
أرجو من إخواني الأفاضل أن يفيدوني في ثقب افقي لمواسير من الحديد المرن قطر 110 مم بطول 600 متر تحت طريق رئيسي
3 مارس 2008
تسنخدم طريقة MICROTUNNELING وتسمى ايضا pipe jacking اي حفر وتركيب الانابيب تحت الشوارع بدون قطعها ويتم ذلك من خلال عمل shaft ومن ثم تنزيل معدات الحفر وتركيب الانابيب بالشافت حتى يتم الوصل الى الشافت بالمنطقة المقابلة.
Microtunneling
is a process that uses a remotely controlled Microtunnel Boring Machine (MTBM) combined with the pipe jacking technique to directly install product pipelines underground in a single pass. This process avoids the need to have long stretches of open trench for pipe laying, which causes extreme disruption to the community. In the U.S., microtunneling has been used to install pipe from twelve inches to twelve feet in diameter. Therefore, the definition for microtunneling in the U.S. does not necessarily include size. Microtunneling has evolved in the US to describe a tunneling process where the workforce does not routinely work in the tunnel. Microtunneling is currently the most accurate pipeline installation method. Line and grade tolerances of one inch are the microtunneling industry standard. This can be extremely important when trying to install a new pipeline in an area where a maze of underground utility lines already exists.
Microtunneling was developed by the Japanese in the early 1970’s to replace open sewers in urban areas with underground gravity sewers. The first microtunneling project in the U.S. occurred in south Florida in 1984.This was a 600 foot crossing with 72" pipe under I 95 and the FEC Railroad. Although originally designed for gravity sewer construction, microtunneling installations include underground crossings of highways, railroads, runways, rivers, and environmentally sensitive areas for a variety of utilities. This process has also been used to install plant intakes and outfalls. Microtunneling is also used in the pipe arch technique of supporting large underground openings with an arch or roof made up of
small
واليك مثال مصور بذلك​
Pictured Above: Welding steel entrance rings for the launching of the head into each tunnel. Palmetto Expressway, Miami Florida. ACCURACY: Less than 30" between tunnels.
Pictured Above: ACCURACY! No room for error on this project - the tunnel had to go through this opening in the water treatment plant and it was right on the money! (Pembroke Pump Station)
Pictured Above: Pembroke Pump Station - Tunnel Machine entering the receiving shaft. Water is not a problem!
Pictured Above: MINIMAL GROUND DISRUPTION: VDOT - Alexandria Virginia: Huxted Tunneling installed a 75.5 inch O.D. tunnel 184 feet long under the Beltway for Shirley Contracting, LLC. The tunnel was installed successfully with less than five feet of cover over the top of the pipe. Ground radar confirmed there was no loss of ground or voids caused by the tunnel, and grouting was not necessary.
Pictured Above: VDOT Virginia project - tunnel machine entering the receiving shaft.
Pictured Above: Work doesn't always stop when the sun goes down.
Pictured Above: Earplugs are a must when working at the Miami International Airport
Pictured above: Accuracy and limited ground cover, 72” RCP
Pictured above: Excavated soil removed from slurry.
Pictured above: Changing direction with 66” steel pipe.
Pictured above: Large pipe or small, 18" vitrified clay pipe.
Pictured above: Triple-barrel accuracy with 72" RCP
واليك افلام قصيرة تشرح ذلك
Micro Tunneling - YouTube
heno9
25 أغسطس 2011
جزاك الله خيرا يا مهندس رزق بس الصور دي لمشروع ضخم لكن المواسير عندي 110 مم هل تنتطبق عليها نفس الجهزة وحجم المعدات السابقة
3 مارس 2008
اقل قطر يمكن استخدامة بنظام jacking pipe هو 12 انش اي 300 مم وبسبب الطول لديك قد تحتاج الى عمل اكثر من شافت على طول المسافة بحدود 200 م.
وهذا العمل يحتاج الى معدات وشركات متخصصة.
Tariq Ameen
22 مايو 2013
أخي العزيز مهندس / رزق
على ما يبدو أن لديكم خبرة واسعة في مجال الثقب الأفقي ... بارك الله لكم فيما وهبكم
أرجوا منكم تزويدنا بالسعر التقريبي للمتر قطر 800 ملم بإستخدام تقنية Micro Tunelling في منطقة صخرية شديدة الصلابة
شاكر لكم طيب تعاونكم
3 مارس 2008
للحصول على افضل سعر عليك طلب السعر من شركات المقاولات المتخصصة في هذا المجال في بلدك.
وبعدها تدرس هذه الاسعار مع دراسة الناحية الفنية لهذه الشركات من حيث مدة التنفيذ والمقدرة والخبرات السابقة وحسن تعاملها وسمعة الشركة.
مع تمنياتي لك بالتوفيق
shameed
27 يناير 2014
الله يعطيك مهندس رزق على هذا الموضوع الممتاز.
عندي سؤالين
1- كم أقل عمق نستطيع استخدام الحفر المثقبي؟
2- هل يمكن استخدام الحفر المثقبي في إصلاح تسربات المياه؟
وشكراً
22 أغسطس 2007
يمكن استخدام طريقة الحفر النفقي الموجه horizantal directional drilling والتي يرمز لها باختصار hdd لمثل هذه القياسات من الانابيب
sayd310
19 مارس 2015
الثقب الافقي (الحفر النفقي)
نحن شركة متخصصة في حفريات الثقب الافقي لخطوط (المياه- الكهرباء- الصرف الصحي-الهاتف) داخل المملكة العربية السعودية لطلب تسعيرات المراسلة على الايميل sayd310 a hotmail
او الاتصال:0550818833
