لمن يريد تحميل auto cad 2012
eng.hamada adel
14 ديسمبر 2010
ده موقع التحميل
http://forums.mazika2day.com/t130763.html
شرح الكراك اتفضلو بس انا شغال 2009
.Install Autodesk Autocad 2012
2.Use as Serial 666-69696969, 667-98989898, 400-45454545 .. or anything matching those templates
3.Use as Product Key 001D1
4.Finish the installation & restart Autodesk Product
5.Before clicking on Activate
You have 2 options :
- a) Disable Your network Card, pull the network cable out or block with firewall
(this is just to disable online serial check)
OR
- b) Click on Activate and it will tell you that your serial is wrong, simply click
on close et click on activate again.
Choose option a or b.
6. Select I have an activation code from Autodesk
7.Once at the activation screen:
start XFORCE Keygen 32bits version if you are installing a 32bits application and
64bits if you are installing a 64bits application.
8.Click on Mem Patch (you should see successfully patched)
9.Copy the request code into the keygen and press generate
10.Now copy the activation code back to the activation screen and click Next
You have a fully registered autodesk product
NB:
1.Make sure you are running the Keygen as administrator and with UAC off on Vista or Windows7
but you have to anyway to install Adesk products
ارجو الانتباه الى هذه الملاحظه
NB:
لا اله الا انت سبحانك انى كنت من الظالمين
h_s0404
12 يوليو 2011
شكراا جزيلا سوف اقوم اولا بترجمة هذة المعلومات الدقيقة والتى تخص تفعيل البرنامج ولكن سوف اقوم اولا بتنزيل مترجم ومن ثم سوف اعود لتحميل البرنامج.
body55
13 مايو 2006
شكراا جزيلا cccccccccccccccccccccccccc
