Car Seats & Seat Belts
safety113
6 ديسمبر 2008
When you get into a vehicle, before the key is turned and the vehicle
starts, everyone should be buckled up. The seatbelt should fit you
snuggly across your collarbone and hips. All children under the age of four must ride in a car seat. It is important to make sure that the car seat fits the child and that it is properly installed in the vehicle.
Air bags save lives.
  • Air bags were designed to work WITH seatbelts to prevent injury to an adult sized person.
  • If air bags open in an crash, children in the front seat or in a car seat in the front seat may be seriously injured.
The safest place for all children under the age of thirteen is in the back seat.
"Kids in back, everybody buckled up".
If you will be riding your bike or in-line skating by the side of a road, you will need to know what these traffic signs and signals mean.
A sign like this one means that there is a bike lane or bike path. If there is a bike path or bike lane on the side of the road, you are required by law to use it. If there is not a bike lane, you should ride with traffic as far
to the right side of the road as possible.
When the signal light turns green, cars go. When you cross the street at a signal light, you should wait for the walk signal. Some corners don't have a walk signal, so you should wait for the green light to show in your direction. Remember that cars may be turning, so be sure to look
carefully to the
left, right and left again, before crossing the street
The WALK signal is found at busy intersections. It means that it is okay for you to cross the street. BUT you should always look both ways, by looking to the
left, right and left again, to make sure no cars are coming or turning into the area where you are going to cross the street
This signal is the same as the WALK sign. It has a picture of a person walking instead of using the word WALK.
When the signal light turns yellow, car drivers should slow down and prepare to stop. If you are waiting to cross the street, you should not cross if the light is yellow. The light is about to turn red, but cars will enter the intersection.
When the signal light turns red, car drivers should stop. If the light is
red in your direction, you should not walk across the street
The DON'T WALK signal is on the same signal as the WALK signal. You should wait to cross the street until the signal changes to WALK.
This signal is the same as the DON'T WALK sign. It is part of the signal with the picture of a person walking. This is a picture of a red hand, meaning you should stop. You should wait to cross the street until the green picture of the person walking is showing.
Car drivers, bikers and in-line skaters must come to a complete stop at STOP signs. When there are no vehicles or pedestrians in the intersection and it is safe, you may go through the intersection.
A yield sign means to slow down and be ready to stop.
  • If there are pedestrians or vehicles in or nearing the intersection, you must stop.
  • If there is no traffic in or nearing the intersection and it is safe, you may go through.
Do not enter means that this is a one way street and you may not go this way. This is also a rule for bikers and in-line skaters
This is a one way street, car drivers may only go in the direction of the
arrow. This is also a rule for bikers and in-line skaters.
This sign means you are coming to a crosswalk.
  • Car drivers, bikers and in-line skaters must stop to allow people in the crosswalk to cross the street.
  • If you are using a crosswalk to cross the street, you should look carefully to the
  • again to be sure it is safe to cross.
This sign means that you are coming to an intersection and should be prepared to stop. At a busy intersection, it is safer to walk your bike across the street instead of riding it.
This sign means you are near a school crossing zone. For more information see:
This sign means you are coming to a railroad crossing. Railroad tracks are uneven. You should not try to bicycle or in-line skate over them. For more information see:
When people are working on the roads, parts of the road or sidewalk are often dug up or rough. Be careful when walking, bicycling or in-line skating. Uneven, rough roads could make you fall off your bike or in-line skates. If you must move into the road to go around a work area, you should stop and look carefully to be sure there is no traffic coming before going into the road.
A detour is a way of getting around a roadway that is closed. Roads are usually closed because of road work or dangerous conditions. If you
must take a detour, use caution on roads you aren't used to
These signs show the directions and distances to towns and cities.
ecc1010
5 يناير 2011
للهم إجعل مصر أمنة مطمئنة وسائر بلاد المسلمين إلى يوم الدين
اللهم ولى من يصلح البلاد والعباد
اللهم ولى خيارنا ولا تولى شرارنا
اللهم أمين وجزاك الله خيرا
ecc1010
5 يناير 2011
