طارق حسن محمد
- إنضم
- 23 نوفمبر 2009
- المشاركات
- 1,186
- مجموع الإعجابات
- 34
- النقاط
- 0
In this article , we will talk about cooling system of the internal compustion engines.The high working temperatures of the internal combustion engine which are the cause of its high efficiency are at the same time a source of great practical difficulty in construction and operation. No known materials are capable of enduring continuously the high temperatures to which the cylinder, piston
and valves are subjected while at the same time retaining sufficient strength to withstand the high working loads. The maximum temperature during combustion is approximately the melting
point of platinum and the temperature even of the exhaust gases is above that of aluminium. It is thus essential that heat be abstracted from the parts enumerated above at a sufficient rate to prevent a dangerous temperature being reached, for, unfortunately, it is quite impossible to prevent heat entering the metal from the hot gases.
The following videos illustrating all you need to know about cooling system
1-Water colling system
2-Air colling system
http://www.youtube.com/watch?v=jpkrFwJzLfQ
3-Coolent used in water colling system
http://www.youtube.com/watch?v=cbnDHcEPumI
http://www.youtube.com/watch?v=BfIoZx8EHRU
4-Cooling system fan
http://www.youtube.com/watch?v=Ap7qWYOdYDc
5-Cooling system hoses
http://www.youtube.com/watch?v=uaoW27s1WoU
6-Colling system water pump
http://www.youtube.com/watch?v=l0BwpPNTyrc
7-Cooling system thermostate
http://www.youtube.com/watch?v=0R1zxDu2uVc
8-Cooling system radiator
http://www.youtube.com/watch?v=GA7X8RQza0k
Thursday, February 3, 2011
Automotive engine Lubrication
After you know the main engine components and engine working principle, we will discuss the secondary systems that are essential for engine operation which are:
1-lubrication system
2-cooling system (water cooling and air cooling)
3-fuel supply to engine
Each system will be discused in details
1-lubrication system:
Lubrication serves the following purpuses:
- Reduction of the resistance to relative motion between the surfaces.
- Prevention of seizure.
- Reduction of the rate of wear of the sliding surfaces.
- To carry away the heat generated by the friction.
lubrication system history:
Early engines had only elementary lubrication systems. Up to the 1920s,
some had manual pumps that were actuated intermittently. For others, up to
the 1930s, oil was fed by gravity from a tank through a pipe to the crankcase,
where it was either piped directly, or passed through ducts in the casting, to
the main bearings, the flow generally being manually regulated by a needle
valve. Alternatively, it was delivered into the base of the casting, whence it
was whipped up by the rotating cranks into a fine mist to lubricate all the
other moving parts.
The following videos illustrate the lubrication system and its components
1-Dry sump oil tank
http://www.youtube.com/watch?v=RryApAqsReM
2-Dry Sumb System
http://www.youtube.com/watch?v=2ChufEfcfJw
3-Engine Friction
http://www.youtube.com/watch?v=AHJMMO0sBlk
4-Engine oil sumb
http://www.youtube.com/watch?v=dSHoZiopYBk
5-Full Pressure lubrication System
http://www.youtube.com/watch?v=4ASBASbxfWo
6-Ovelall lubrication System
http://www.youtube.com/watch?v=SG66-KraevY
7-oil Addidtives
http://www.youtube.com/watch?v=m7BCRtPan_M
8-oil Coolers
http://www.youtube.com/watch?v=K7JdeCoWbmA
9-Oil Pick up tube
http://www.youtube.com/watch?v=1zUsjmUorbo
10-oil pressure gauges and ligths
http://www.youtube.com/watch?v=jdPHRkk_k7Y
11-Pressure relive valves
http://www.youtube.com/watch?v=WXQQ_AHM0aE
12-Rotary engine lubrication System
http://www.youtube.com/watch?v=udIp9VWIE6E
13-Splash Lubrication
14-Oil Viscosity
http://www.youtube.com/watch?v=LMZjgKZAXlI
Friday, January 14, 2011
All you want to know about your car engine
The petrol or oil engine, which is the source of power with which we are
immediately concerned, is a form of internal combustion ‘heat engine’, the
function of which is to convert potential heat energy contained in the fuel
into mechanical work.
Engine main components:
Cylinder: The ideal form consists of a plain cylindrical barrel in which the
piston slides
Piston: The usual form of piston for internal combustion engines is an
inverted bucket-shape, machined to a close (but free sliding) fit in the cylinder
barrel. Gas tightness is secured by means of flexible ‘piston rings’ fitting
closely in grooves turned in the upper part of the piston.
Connecting rod:The connecting rod transmits the piston load to the crank,
causing the latter to turn, thus converting the reciprocating motion of the
piston into a rotary motion of the crankshaft. The lower end, or ‘big end’, of
the connecting rod turns on the crank pin.
Crankshaft: In the great majority of internal combustion engines this is of
the double-web type, the crank pin, webs and shaft being usually formed
from a solid forging. The shaft turns in two or more main bearings (depending
on the number and arrangement of the cylinders) mounted in the main frame
or ‘crankcase’ of the engine.
Flywheel: At one end the crankshaft carries a heavy flywheel, the function
of which is to absorb the variations in impulse transmitted to the shaft by the
gas and inertia loads and to drive the pistons over the dead points and idle
strokes. In motor vehicles the flywheel usually forms one member of the
clutch through which the power is transmitted to the road wheels.
Previous parts are the main mechanical components of the engine,but in fact there are many systems which grantee that the engine is working properly like lubrication system,cooling system and many ather systems that will be discused later in details
Hey,here you are a complete set of videos describe in details all engine components:
The 2 strock engine principle and operation
http://www.flixya.com/video/4031647/The-2-strock-cycle-engine-operation-principals
Cam Shaft function,operation and manufacturing
http://www.flixya.com/video/4031649/Cam-shaft-function-operation-and-manufacturing
Compustion chamber shape and operation
http://www.flixya.com/video/4031650/Compustion-chamber-types-configurations-and-performance
Connecting rod function,operation and manufacturing
http://www.flixya.com/video/4031654/Connecting-rod-functionoperation-and-manufacturing
Cranck shaft function,operation and manufacturing
http://www.flixya.com/video/4031655/Cranck-shaft-functionoperation-and-manufacturing
Engine block manufactring and operation
http://www.flixya.com/video/4031657/Engine-block-manufactring-and-operation
ICE cylinder linar operation and function
http://www.flixya.com/video/4031659/ICE-Cylinder-linar-operation-and-function
ICE sliding bearings types and location
http://www.flixya.com/video/4031660/ICE-sliding-bearing-types-and-locations
ICE flywheel construction,operation and functions
http://www.flixya.com/video/4031662/ICE-fly-whell-constructionoperation-and-functions
ICE overhear cam gear train operation and construction
http://www.flixya.com/video/4031663/Overhead-camgear-train-system-function-and-operation
ICE piston rings operation,function and manufacturing
http://www.flixya.com/video/4031665/ICE-piston-rings-operation-manufacturing-and-maintenance
Pistons operation,functions and manufacturing
http://www.flixya.com/video/4031667/ICE-main-power-sourcepistons-operation-function-and-manufacturing
Valves guides installation and machining
http://www.flixya.com/video/4031668/ICE-valve-guides-and-how-it-is-overhouled-and-installed
ICE valve seats installing and machining
http://www.flixya.com/video/4031671/ICE-valve-seats-contact-machining-and-installing
Effect of the valve size on the overall performance of the vehicle
http://www.flixya.com/video/4031673/Effect-of-ICE-valve-size-on-the-overall-performance-of-the-engine
ICE oil seals
http://www.flixya.com/video/4031674/Internal-compustion-engines-valve-types-and-maintenance
ICE valve seats machining and installation
http://www.flixya.com/video/4031678/Inernal-compustion-chambers-vslve-seats-installation
Refrence:The Motor Vehicle 13th edition
Do you know the main components of your vehicle?
Hi all of you
Let us begin
Today we will talk about introduction to your car
Do you know what are the components of your car?
Your car is a very complicated integrated system This system is devided to many sub systems.
The main systems of any vehicle are:
1- Engine:it is the power source of the vehicle
2- Braking system: this system is responsible for stopping and decelerate the vehicle
3- Powertrain:it includes clutch,gearbox,driveline and differential,this system is responsible for transmit engine torque to the tires
4- Tires and suspension systems:responsible to develop sufficient tractive effort and braking and cornering effort and to isolate road input
5- Steering system:steering system is the main difference between road vehicles and trains
6- Body:it is the skeleton which include all previous systems and passengers or goods
Each system will be discussed in details
And now here you are your first video set
This video show you the main components of any vehicle
Vehicle main components
http://www.flixya.com/video/4031646/Veihcle-main-components-illustration-and-de******************ion
And in this video you will see how sheet metal is converted to an amazing car
Car manufacturing video part 1
http://www.flixya.com/video/4031638/Complete-Vehicle-mnaufacturing-part-1
car manufacturing video part 2
http://www.flixya.com/video/4031641/Complete-vehicle-manufacturing-part-2
Hi all of you
Let us begin
منقوووووووووووووووووول
