حل مسالة
روح طفله
4 نوفمبر 2010
The rate of flow of water pumped into a pipe ABC, which is 200m long is 20lit/sec. The pipe is laid on an upward slope of 1 in 40. The length of the portion AB is 100m and it?s diameter is 10cm, while the length of the portion BC is also 100m but it?s diameter is 20cm. The change of diameter at B is sudden. The flow is taking place from A to C where the pressure at A is 19.62N/cm2and end C is connected to a tank. Find the pressure at C taking f=0.008
اخوااااان عااااااجل أريد حل هذه المسئله
الدكتور قالنا داخل في الإمتحاان وما عطانا الحل :(
اتمنى حلها
الأمتحان قرييييييييب.
روح طفله
4 نوفمبر 2010
عااااااااااااااااااااااااااااااااااااااااجل أخوووتي
الإمتحاان غداً
