Mathcad Enterprise Edition 13.1 (Full)
yassine-maroc
15 مارس 2006
[BIMG]http://www.tradehas.sk/images/mc13Box.jpg[/BIMG]
Salamo alikom
Mathcad's open application architecture combined with its support of .NET and its native XML format make it easy to integrate Mathcad into existing IT structures and other engineering applications.
With one of the largest user bases in the engineering world, Mathcad is easy to learn and use—no special programming skills are required. Mathcad documentation and context-sensitive help make learning and using Mathcad an intuitive process. Tutorials for both new and experienced Mathcad users step you through common as well as complex operations.
Calculate, model, and visualize your ideas
Mathcad provides hundreds of operators and built-in functions for solving technical problems. Use Mathcad to perform numeric calculations or to find symbolic solutions. It automatically tracks and converts units and operates on scalars, vectors, and matrices.
Mathcad's 2-D and 3-D graphing capabilities give you better insight into your work, and precise control over your graphs. Cartesian, polar, surface, contour, bar, scatter, and vector-field plots are all available.
Document your calculations so your entire solution is contained and documented in one place to your exact specifications.
Integrate data across software and systems, thanks to connectivity with popular desktop applications.
  • Nouveau.txt
    49 بايت · المشاهدات: 85
MUSLIM125
22 يوليو 2005
جزاك الله خير .برنامج الMathcadغنى عن التعريف
