Carbon Steel Corrosion - Bypass Tower
NasserAlnaimi
21 أبريل 2006
Hello
Current Material - A 36 or A 515
Environment - chlorides (~1.5%); SO2 ( ~ 0.13%) and coal (~ 1% S)
Mechanism : The gas entering the system will be around 1100 C, and will be quenched by fresh air down to about 350 C. Most of the chlorides and alkalis should condense on the dust. The gas / dust stream then will pass to the conditioning tower (bypass). NOTE: Basically, one of the the fuels the plant will use is a liquid waste from the manufacture of industrial chemicals, which leads to the high amount of chloride present in the fuel. The chloride will be in liquid phase from the storage tanks up to the burner pipe , after which point it will be a vapor. The vapor will condense to a solid coating in the cooler portions of the tower
QUESTIONS
Would a 50 % / 50 % Cr - Ni alloy be an overkill to avoid both pitting and general corrosion , as well as sulfidation ? Any alloy suggestions The current carbon steels in use are not lasting too long
Regardless the alloy selected , would carbon steel thermal sprayed with the new selected alloy be an option
Have you ever heard about "FLUEGARD-425" as a coating option for gas conditioning towers
Any suggestions for the above questions would be greatly appreciated​
