Compact Laser Diode Modules with Line Generating Optics
A range of compact and affordable laser modules generating an accurate line at 635nm or 650nm with uniform intensity distribution. The laser modules measure just 29mm in length, with a diameter of only 8mm and are extremely efficient and reliable.
They are ideal for the most demanding industrial and medical applications where space is at a premium, such as handheld instrumentation, targeting, alignment and machine vision.
buy now
These laser diode modules generate either a 58° or 88° full angle line, factory focused at 1000mm. The focus can be set at other distances on request. The lens system produces an efficiently uniform intensity laser line.
At a visible wavelength of either 650nm or 635nm, these compact laser diode modules offer output powers of 0.9mW or 4mW with power stability of less than 5 per cent. Operating voltage is from 3V to 6V DC at an operating current of 30mA typ, (0.9mW) or 40mA typ, (4mW). Operating temperature range is -10° C to +40° C.
The laser modules consist of a brass housing, a laser diode, drive circuit and beam-shaping optics. Electrical connections are made via external flying leads. All modules have static, surge and reverse polarity circuit protection.
