مجنون هندسه
- إنضم
- 1 يونيو 2009
- المشاركات
- 4
- مجموع الإعجابات
- 0
- النقاط
- 0
مرحبا
شباب انا عندي بروجيكت
فالذي عنده خبره الرجاء مساعدتي
هذا هو المطلوب
The torsional loading apparatus is used in the Mechanics of Materials Laboratory as an experiment measuring the strain on a pipe caused by torsional loading in the elastic region.
The final design should consist of the following: base plate, steel pipe, dowel, steady rest, loading arm, weights, set screws and fixed end block, and strain rosette. The base plate is used to secure all of the other parts together. The steel pipe is the sample that was loaded and the subsequent strain was measured using the strain rosette. The dowel is fitted in a grove to create a key which kept the steady rest square to the pipe. The steady rest is used to support the loaded end of the pipe so the pipe is loaded only in torsion, not in bending. The load is applied at some fixed distance from the pipe using the loading arm. The weights are hung from the loading arm to create the desired torque on the pipe. Set screws are tightened against the pipe to create a fixed end that would not rotate, and to attach the loading arm to the pipe. The fixed end block provided a place to anchor the pipe to resist the rotation caused by the torque on the pipe. This experiment should be designed to test pipes with diameters ranging from 1/2 to 2 in.
In SolidWorks do the following:
ارجو مساعدتي ......
وشكرا للجميع
هذا هو المطلوب
- Create SolidWorks models and 2D working drawing of the parts of the final concept.
- Create a fully detailed working assembly drawings of the device with part list.
ارجو مساعدتي ......
وشكرا للجميع
